BeetlePD
Anybody tried it on their pre-2009 TDI? What were the results? I’ve done it with my Honda Civic and oil analysis showed the oil was still good at 20k
This web site is a waste if you don't search first and find the info
http://forums.tdiclub.com/showthread.php?p=3394436#post3394436I did do a search for 20,000 miles and scoured the UOA thread for extended drain, but after thirty minutes found nothing
Thank you. Your response is more helpful than Lightflyer’shttp://forums.tdiclub.com/showthread.php?p=3394436#post3394436
Scurvy got close to the oci you are seeking. He was also running a bypass filter.
You are welcome. I hope that if you chose to go that route that you Uoa along the way there just to be on the safe side. And that you post your experience and results here in this thread.It could also be the search function doesn’t work as well as you think. After wasting 30 minutes searching I decided it’s easier to just ask. After all that’s what forums are for (to post).
He was also adding zinc and moly adds and adding fresh oil along the way. So what was the point? Spend money on a bypass filter, spend money on some crap to add to the oil and still ended up adding more oil along the way. What was the savings over just changing the oil as per the 10k maintenance schedule? Actually, I think he spent more.http://forums.tdiclub.com/showthread.php?p=3394436#post3394436
Well let's think about it...........4k per year 40k in ten years, 80k in 20 years. How old are you? And how many years are you concerned about driving your car. 160k in 40 years. If I was you I wouldn't change the oil at all. You will probably die before the car fails. And everything else on the car too before the engine fails to do to lack of proper lubrication. Just change your oil once a year and forget about it. Really how cheap are you?I get the 20,000 mile OCI OK............
How about time? Would 4,000 miles per year with a 2 year OCI be pushing the envelope too much?
ez
For the most part I totally agree with you. However, the one caveat here is the cam issues in the PD. If his OCD of using moly and zink saved his cam and lifters it may be worth it in the end. Of course, we know those can be a crapshoot no matter how good of oil or what OCI you use... so who knows.He was also adding zinc and moly adds and adding fresh oil along the way. So what was the point? Spend money on a bypass filter, spend money on some crap to add to the oil and still ended up adding more oil along the way. What was the savings over just changing the oil as per the 10k maintenance schedule? Actually, I think he spent more.
I'm with MichaelB... if you are putting on 4k a year I'd change it once a year and call it day. Knowing how lazy I am, I might even go change it once every two years, but I would by no means give that as advice for anyone else, I just know me.I get the 20,000 mile OCI OK............
ez
I would say your question is a good one but very broad in terms of 'Pre-2009 TDI' and that's why you will get many answers and not necessarily a 'yes/no'.Anybody tried it on their pre-2009 TDI? What were the results? I’ve done it with my Honda Civic and oil analysis showed the oil was still good at 20k
So I say what's the point? Blackstone Labs oil analysis is 28 bucks. What does an oil change cost? 20 bucks or less for a jug of Rotella T6. I am not sure of the cost for a PD oil filter cuz I don't buy them for my car. Change the oil at 10k. Forget about extended OCI unless you are a real environmental freak and don't want to use up too many resources stretch the last drop out of the oil and only have 1 filter to dispose of as opposed to two. There is no monetary benefit.Most people would agree that to go beyond 10K oil change interval (OCI) you will do a used oil analysis (UOA) with TBN (total base number) included in it and then make a decision.
How many UOA's does a good baseline constitute? 28 bucks per UOA. Man money is money why not spend the least of it. I know it might be kinda fun/interesting to read the reports. I also know you could piss away 28 bucks on less beneficial things. But my understanding is to increase your OCI is to save money not spend more. Increasing the OCI will not make your engine run better or last longer.I would say it depends on your situation. If you have a good UOA baseline
Good conversation!
Well let's think about it........... If I WAS you I would Just change your oil once a year and forget about it.................
Old age I guessAh, Senor: you were very helpful when I had questions concerning my JSW TDI 6M buyback...............
Why the change in style?
thanks,
ez
He said, uselessly....The forum is to post and learn things. Not just generate useless posts.
I would buy the vw dealer 5w-30 castrol 507 and filters for your Mk VI and change every two years in the fall if you are more to the north. The high detergent and anti-oxidants of the synthetic diesel oil are beneficial to a low mileage vehical. In fact I would put diesel oil in a classic car that is stored over winter and seldom used to prevent acidic corrosion by taking advantage of the the high TBN of the diesel oil.I get the 20,000 mile OCI OK............
ez
That may be why the engine builder of my 'classic' small-block told me to use Rotella T5.I would buy the vw dealer 5w-30 castrol 507 and filters for your Mk VI and change every two years in the fall if you are more to the north. The high detergent and anti-oxidants of the synthetic diesel oil are beneficial to a low mileage vehical. In fact I would put diesel oil in a classic car that is stored over winter and seldom used to prevent acidic corrosion by taking advantage of the the high TBN of the diesel oil.
That sounds like a DEAD forum with no new posts of any kind. Is that what you are trying to achieve? Silence?The forum is to post and learn things. Not just generate useless posts.
Nope. Just do a search first (a real one this time) and find the info that is already here. It isn't useful at all to have the same question asked over and over and over again just because you are too lazy to search first and find the existing info/facts.That sounds like a DEAD forum with no new posts of any kind. Is that what you are trying to achieve? Silence?
