passatforbus
- Joined
- Jan 20, 2015
- Location
- NC
- TDI
- 97 jetta tdi 244k stage 2 Malone Bosch injectors, 98 jetta tdi 240k injectors.
I have an ALH married to a w56.
The tanny mount is set.*
My question is about mounting the motor
- The alh has a front motor mount from the stock engine. I was thinking about using this. I have seen a few toyota swaps that use this mount. They fab up a bar across the front of the motor and use an isolator at each side.* But it would mean.
#1 This mount will be taking all the tortional force of the motor.
#2 And the total weight of the assembly is hung between the very front of the motor and back of the tranny.
"Less work"
The second method would be to fab a mount on ither side of the motor. "More work"
Note. I'm trying to use the kiss principal "keep it simple stupid".
This front mount/2 isolator setup would be very easy to fab up. I have plenty of room.
It seems to have worked for these others.
But I'm not confidant with it yet. Any body have some pointers?
"Less work"
