Muffin; Here is some more info so you can make an informed choice;
http://forums.tdiclub.com/All-Season Vs. Touring Vs. Performance
All-Season tread designs will provide good all-around traction for varying road conditions such as Wet, Snow and Ice, but still provide good Treadwear & Tire Noise characteristics. Performance tread designs have been engineered to Enhance a vehicles Handling capabilities on wet and dry roads, but usually exhibit increased Tire Noise and Lack Long Treadwear Life. Performance tread designs usually have larger tread elements to provide a stiff tread area for handling performance. Touring tread designs were designed to bridge the gap between All-Season & Performance tires. Touring tread designs combine the technology for good treadwear characteristics from All-Season tires and handling & grip associated with Performance tires. Touring tires also exhibit very good Tire Noise and Ride Comfort.
http://forums.tdiclub.com/Treadwear Performance Vs. Grip/ Handling/ Traction Performance...
The treadwear-traction trade-off has been a focus in Tire Performance-Enhancement Technology for decades. Tire companies have been trying to reduce the trade-off between treadwear & traction through the development of new rubber, new tread designs, and new tire construction techniques. Basically, a tire will wear-out quickly if it is providing maximum grip to the road. This is due to the tread rubber being torn from the tire (on a microscopic level), while it is adhering to the road surface. An excellent treadwear tire minimizes the amount of rubber being removed at the road surface; thus providing long tread life, but less road gripping traction.
http://forums.tdiclub.com/Tire Speed-Rating ("S","T","H","V","W","Y","Z")
A common Trade-Off for higher Speed-Rating is reduced Ride Comfort. An "S" Speed-Rated tire will give a more comfortable Ride compared to "H" Speed-Rated tire, and a "H" Speed-Rated tire will give a more comfortable Ride compared to a "Z" Speed-Rated tire. The Ride Comfort Characteristics can be attributed to the tire's Overall Stiffness. A tire capable of running at High Speeds requires a more stiff construction, in order to provide the necessary high speed stability & durability.
Tire Speed Rating Symbols:
S180km/h or 112mph T190km/h or 118mph U200km/h or 125mph H210km/h or 130mph V240km/h or 149mph W(ZR)270km/h or 168mph Y(ZR)300km/h or 186mph ZRAbove 300km/h or 186mph
A Z-Speed Rated tire without a Service Description means that the customer must consult the Tire Manufacturer to obtain the tire's Maximum Speed Capability.
As long as the load rating is correct and the speed rating you pick is not one you normally exceed then it is all personal choice. Do you have something like
www.tirerack.com or
www.1010tires.com that you can use to check user reviews?
