Old February 16th, 2017, 12:46   #1
kepsu
TDI(s): golf III tdi
Default Turbocharger for Land Rover 300tdi
Hello! I'm looking for a replacement turbo for a Land Rover 300tdi engine. 2,5 liter 4-cylinder, 11mm distributor pump, nozzles are ,260. Some new vnt would be nice but no electronic engine control so i guess that rules it out. Would like to get more torque down low, originally it makes 200lbft@1800rpm. Original turbo is jurassic garrett t250-04, compressor exducer 53mm and turbine inducer 47. Car will seldom see more than 3500 rpm. Any thoughts? Holset he211w maybe? I know this car is not a vag but there is so much knowledge here.
kepsu is online now   Reply With Quote
Old February 17th, 2017, 01:56   #2
mk1-83
Fuel Economy: 1:15
yes he221w ore better hy35 with small ex housing 8-6cm
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old February 17th, 2017, 11:57   #3
kepsu
Would the he211w be better a better choice as it has 56mm compressor vs 60mm for he221w. Also the 211 has #5 turbine housing as the 221 comes with #7 housing? What about he200w?
Old February 17th, 2017, 13:00   #4
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
there are multiple size housings available. my HE221 has a 6cm housing and username "nitec" I think sells them with a 5.5cm
1996 passat TDI - "Red Death" 11mm pump, R520, GT15/17 hybrid. For now...
1997 passat TDI wagon - waiting in bullpen for the 1996 to quit...
ketchupshirt88 is offline   Reply With Quote
Old February 17th, 2017, 13:11   #5
mk1-83
Fuel Economy: 1:15
2.5 needs a 60mm comp works fine
Lupo 1.9 tdi
300+ HP 500 nm
Old February 18th, 2017, 06:05   #6
majesty78
majesty78's Avatar
Fuel Economy: 30mpg
There is a very rare OE Garrett VNT which is simply pressure controlled, they where made for LandRover Aftermarket Turbo Kit.
Sizewize it is about GT2556V size, so "relative" big thing.
I have a broken one in my workshop from which I can tell you the part number on monday if from any interest.
As alternative choice there also is a pressure controlled Garrett VNT from some early Alfa Romeo engine....
Garrett 454150-5006S
Seat Leon Cupra R MK1 no more dizzel in da hood :-(
majesty78 is offline   Reply With Quote
Old February 18th, 2017, 09:11   #7
kepsu
A pressure controlled vnt might also work but wouldn't there be a problem with toi much boost on low throttle, for example cruising on highway. I know that some have built systems where the vanes are default open. Throttle cable closes the vanes via a spring mechanism when pedal is pushed. When required boost pressure is achieved pressure actuated mechanism opens the vanes. These systems might work but there must be quite a lot of adjusting and tuning involved. There are also aftermarket digital vnt controllers for example digibooster. Didn't find any user comments about that however.
Old February 19th, 2017, 10:56   #8
mk1-83
Fuel Economy: 1:15
long time ago i did gt20 with pressure vnt it works but not perfect after time vnt gets stuckt by soot because a pressure regul vnt dont move as much as oem.
Lupo 1.9 tdi
300+ HP 500 nm
Old February 20th, 2017, 14:19   #9
[486]
TDI(s): 02 golf ALH
You set up so the lever does not close the vanes so far, crank in stop screw until you get good EMP/IMP at cruise, then have a normal pressure actuator for opening the vanes.
Not quite as good of spool as computer control, as they can clamp down much further without running into restriction at low EGT.
Just do "dumb" wastegate turbo. I'd look for something S200-ish in size. 51mm inducer.
1978 Land Rover mohawk69 TDI Cars for Sale/Wanted 0 April 4th, 2016 19:50
land rover Jack_Berry Sightings 4 July 10th, 2008 13:00
Land ROver 300TDi Tad Non VW Group Diesels 9 July 16th, 2002 01:05
Copyright - TDIClub Online LTD - 2014
1996 - 2015, All Rights Reserved
Page generated in 0.15404 seconds with 12 queries
[Output: 88.57 Kb. compressed to 75.44 Kb. by saving 13.14 Kb. (14.83%)]
