Wanted: 2006 or newer Jetta TDI
bmart
Indiana
2006 vw new beetle tdi
On the hunt for a 2006 or newer tdi Jetta. Can need work or be perfect. The closer to Indiana the better. Prefer an auto but I like the manuals too. 812-890-2382
Freeze Plug
CT
Turd Sandwich
I wish you luck on your quest, but unless you have really deep pockets (not judging here), you'll be stuck with 2006 at the newest or otherwise will be paying VW's buyback price or more
bmart
Indiana
Way too far from me if you are in New York. Prefer to stay closer to Indiana.
bmart
Indiana
I'm in no hurry to find one. My alh is doing just fine. Worst case I buy one after they are fixed.
bmart
Indiana
My opinion is they will have a flooded market and be cheaper. I could be wrong. I loved my last em. I just kinda want another. I won't turn down a common rail though
Fort Worth, TX
2006 Jetta TDI
I have one!
In Fort Worth. 2006 Jetta TDI, automatic. Single owner, all maintenance done according to schedule, just turned 150k two weeks ago. Just found out the transmission is blown and they want $4k to rebuild it. Interested?
suparag
Wichita,KS
None now.
2006 Jetta- Wichita KS
In Wichita, KS - Have a 2006 Jetta TDI with 348K miles on it, all driven by me. Same as above, just found out 3 months ago, that the clutch pack is bad. New clutch pack is $700 + labor or a new DSG transmission $3000 aproximately. It is just sitting here at the local VW guru's shop. Will take $1000 for the car as is.
jay.sejkora2011
Raleigh NC
2012 Passat SEL, 2009 Jetta Sportwagen,2006 Jetta- sold, 2006 Jetta- sold, 2001 Jetta-sold
couple I've been looking at.
https://www.facebook.com/groups/484...84196225007811/?sale_post_id=1284196225007811
(check engine light code is: p0183 durring a short google search it looks minor. Could be an easy wire harness swap if your handy. Going to look today I hope.)
https://washingtondc.craigslist.org/nva/cto/5975419103.html
https://washingtondc.craigslist.org/doc/cto/5961506057.html
https://washingtondc.craigslist.org/mld/cto/5954073595.html
https://www.facebook.com/groups/VWD...0229/?sale_post_id=1214801511930229&ref=br_rs
(Looked at this one, Good option has the delete and tune done. frost heater installed. Needs-headliner, new coolant line is in backseat ready for install, little paint around the bumper, two new tires)
https://www.facebook.com/groups/373...0459/?sale_post_id=1613502355330459&ref=br_rs
Joe Haggerty
Towanda Pa 18848
2009 TouregTdi. 2005 jetta wagon tdi. 2005 Passat wagon tdi
2005 Jetta wagon TDI in PA. Auto tranny 139k
All maintenance records. Good condition
Let me know if interested.
Mad_Max
Lexington KY
'06 Jetta 5sp
Are you still looking?
I'm debating if I want to part with my platinum grey PKG1 '06 5sp with 99K on the clock.
Big ticket items done:
1. Roof liner replaced @ 65K.
2. T-belt kit from IDparts @ 80K. Cam inspected before the T-belt job, no wear was found.
3. Driver seat cover replaced with OEM part @82K.
4. DMF to SMF conversion kit IDParts with both clutch cylinders @ 85K.
Smaller items:
1. Boost gauge in a custom pod.
2. Pioneer head unit (Nav, DVD, micro SD, Ipod, BT) with rear view cam.
3. Amp + 10 inch sub with custom enclosure in the trunk.
4. European cup holder with hard wired Passport radar detector remote control.
5. Oil & filter changes every 5K.
6. Air & fuel filter changes every 20K.
7. Always garaged at home and in a covered parking at work.
I'm in Lexington KY, so not too far from Indiana.
Ping me if interested.
Max
bmart
Indiana
Smaller items:
Max
I sent you a pm
bmart
Indiana
Back on the hunt. I went back to a bew, but now wanting something newer again!
2015TDIManual
Enon Valley, PA
2015 TDI Jetta SEL, 2015 TDI Jetta S
I have a 2015 VW Jetta TDI S. It's a 6 speed manual with 7823 miles. I just listed it for sale the other day. I'm in Pennsylvania.
2015TDIManual
Enon Valley, PA
Have it listed for $16000. Comes with a set of Michelin X-ice snow tires that have less then 2000 miles on them, Oil + filter for next change and I believe I got 2 fuel filters also. I have VCDS for this car if interested. The 11yr 162000 miles warranty is fully transferable also.
