Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old August 31st, 2017, 11:51   #1
Apone
TDI(s): None
Fuel Economy: 40+
Default Keeping doors locked while car is running
hi all I use my 2002 golf for towing and was wandering if theres a way to keep doors locked while car is running for fast stops to refill and get a drink so the turbo can cool off and oil keep pumping threw. I have ross tech software and my skc
matt
Apone is offline   Reply With Quote
Old August 31st, 2017, 13:47   #2
smelly621
Are you planning to carry a spare key to get back in? What CCM behavior prevents you from having the doors locked while running?
How about you roll down the window, get out of the car, close door, reach in and lock the door, then quickly pull the auto-up window switch?
smelly621 is offline   Reply With Quote
Old August 31st, 2017, 23:27   #3
Ol'Rattler
Ol'Rattler's Avatar
Lock it at the door lock with a different key. On my A5, if it is running, the remote will not lock the car but a key in the lock will.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old August 31st, 2017, 23:47   #4
Ol'Rattler
Ol'Rattler's Avatar
Much safer. unlock all the doors, roll up all the window get out of car, close drivers door open the front passengers door, hit the lock switch and close the passenger door.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old September 12th, 2017, 18:22   #5
Scoutx
You should be able to do that with the Remote.
Central Electronics - Long Code Helper
Byte 4 - Bit 2 - Checked.
This should allow you to exit the running car and then lock/unlock the doors with the remote.
http://forums.vwvortex.com/showthrea...S-Mods-(w-pics
2012 - No mods. First Mk6 in 800 mile club & 1000 mile club (Totaled and retired)
2015 - No Mods.
Scoutx is offline   Reply With Quote
Old September 13th, 2017, 06:21   #6
Enabled
"Open/Close Windows via the Key Fob -- 2014+ ONLY"
To do it on MK4 it takes a special eeprom rewrite of the comfort module, not something you can do with coding.
-2003 Jetta TDI GLS Manual (Daily beater. Mods: GLI Springs/Koni Shocks, SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned) 47mpg at 80mph
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car) + BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon
Enabled is offline   Reply With Quote
Old September 14th, 2017, 12:22   #7
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Keep the remote in your pocket for locking and unlocking, and use the valet key for the ignition?
You could put the valet key on a detachable key-ring like this:
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
My car locked the doors on its own. Ed ke6bnl VW MKIV-A4 TDIs (VE and PD) 13 June 24th, 2016 16:54
Battery flat/Doors locked patrickmorris VW MKIV-A4 TDIs (VE and PD) 5 May 11th, 2014 18:56
Battery drain only when doors locked BCKCX2 VW MKIV-A4 TDIs (VE and PD) 6 December 21st, 2012 18:33
Relay chatter when doors locked cada VW MKV-A5 Golf/Jettas 0 October 29th, 2012 11:40
It's -44, and I want to leave car running and lock doors - how? Taz107 VW MKV-A5 Golf/Jettas 32 March 18th, 2007 10:06
Page generated in 0.12670 seconds with 12 queries
[Output: 81.79 Kb. compressed to 70.76 Kb. by saving 11.03 Kb. (13.48%)]
