TDI'ed
Hi guys, so I installed my boost gauge with the line that came with it (a hard plastic line of say 2-3 mm diameter? I bought the new south gauge and kit from kerma.. in it came a larger peice of rubber that 'bridged' the boost fitting on the upper intercooler pipe to the hard plastic line.. basically the hard plastic line was held in by friction only. Well some oil residue has made it into the larger rubber peice and it no longer holds the line.. and some other attempts at fixing it have failed. In addition to this I think I was getting some boost loss through the boostvalve and the car woudl only hold 15psi of boost.. sometimes less. What are you guys running for boost lines? I'd rather run one continuous peice right from the intercooler pipe to the gauge to avoid any further oil residue issues. Also, has anyone experienced this odd 15psi max boost behaviour? I find it odd that the car is consistently boosting to only 15psi even though the tune is requesting 18psi. I thought it was my EGR valve but I have a race pipe in now and it feels liek the same power (can't tell currently as the boost valve is not hooked up). I'll do a log and see but I am hoping for a quick suggestion on some better boost line and where to pick it up? I thoguht about just running a vacuum hose? The smaller diameter stock line seems to be the perfect size for the line out of th eintercooler?
