Biodiesel may contain small but problematic quantities of water. Although it is not miscible with water, it is, like ethanol,
hygroscopic (absorbs water at a molecular level).
[38] One of the reasons biodiesel can absorb water is the persistence of mono and diglycerides left over from an incomplete reaction. These molecules can act as an emulsifier, allowing water to mix with the biodiesel.[
citation needed] In addition, there may be water that is residual to processing or resulting from storage tank
condensation. The presence of water is a problem because:
- Water reduces the heat of combustion of the bulk fuel. This means more smoke, harder starting, less power.
- Water causes corrosion of vital fuel system components: fuel pumps, injector pumps, fuel lines, etc.
- Water & microbes cause the paper element filters in the system to fail (rot), which in turn results in premature failure of the fuel pump due to ingestion of large particles.
- Water freezes to form ice crystals near 0 °C (32 °F). These crystals provide sites for nucleation and accelerate the gelling of the residual fuel.
- Water accelerates the growth of microbe colonies, which can plug up a fuel system. Biodiesel users who have heated fuel tanks therefore face a year-round microbe problem.
- Additionally, water can cause pitting in the pistons on a diesel engine.
Previously, the amount of water contaminating biodiesel has been difficult to measure by taking samples, since water and oil separate. However, it is now possible to measure the water content using water-in-oil sensors.[
citation needed]
Water contamination is also a potential problem when using certain chemical
catalysts involved in the production process, substantially reducing catalytic efficiency of base (high pH) catalysts such as
potassium hydroxide. However, the super-critical methanol production methodology, whereby the transesterification process of oil feedstock and methanol is effectuated under high temperature and pressure, has been shown to be largely unaffected by the presence of water contamination during the production phase.
