Is there a write-up on replacing subframe bushings?
O0_Ia
Virginia
DESTROYED
I would like to replace my OEM subframe bushings with TT subframe bushings, and I'm wondering if there is a write-up on how to do this.
02DslPwr
Leander Texas
2002 Jetta Wagon, TDI
You dont need one, loosen the sub frame and replace them one by one. I used a screw driver to pry them out. You'll destroy them getting them out. IIRC they'll press into place when you tighten them.
