turbodieseldyke
I believe a p.o disabled these 2 warning lights, either to ignore them, or to defraud the next buyer (whom i bought it from).
The bulbs are in the cluster, but they never light up. The airbag light was located in some extraneous slot, like ABS, and I moved it back to the Airbag slot. (i did not verify the bulbs are working. i'll check them when i can.)
There are also some dangling wires behind/above the fuse box:
- Red F wire in a Blue M plug
- Br/Yel M wire in a Black F plug
- Blk/W M wire in a White F plug, comes from D/4
- Blk/Yel M wire in a Grey F plug, comes from D/7
Does anyone recall any experience with these wires? I'm wondering if they could be related to the dead lights. If the M/F connectors matched, i could assume the four were originally plugged into each other, but since the genders are mismatched 3-to-1, two of the males are relegated to "just watching", so to speak.
It's possible the airbag system is shot, as the heater core had previously leaked, and was bypassed. I read on here that sometimes that leak will kill the SRS controller directly beneath it. (Great engineering, btw. Was there no spare room in the front bumper, to mount that computer?)
The only wiring diagram i could find, containing any hint to the airbag light was a 98 V6 that said:
T50/30 ----br/yel---> T1 ----white---> T28b/1. The "Br/Yel" got my hopes up briefly, but i have no idea where T1 is. (it didn't say "T/1"; "T" has 2 pins, and the loose Br/Yel won't fit).
I wish i could answer these myself with a Bentley, but i've read too many posts about how incomplete & inaccurate their wiring diagrams are. i hate to be one of those "There Oughtta be a Law" guys, but every new car should include a full, accurate service manual. That way, Bentley & VW can't point the finger at each other, while leaving us in the dark.
