ninedee_golf_tdi
I posted this in the GLX cluster mod thread but who reads that ? My problem is that I modded the cluster but am not getting the correct results. I must be doing something incorrectly here. I have a 96 glx chassis and the original glx cluster with a tdi swap. I added the two resistors, the led lamp in position 5 and the wire for the mil light. Key on and the new mil lamp glows very faintly, but it does turn on. Put a tdi cluster in and all bulbs work as they should. So.... either the resistor(s) is causing too much voltage drop, or, the resistors are unnecessary to begin with in this application, or the 276-021 3vdc Radio Shack led is too high of a voltage rating ? Any thoughts ? Thanks.
