Old April 23rd, 2019, 17:24   #1
bob022004
Default 2010 Jetta 6 speed shifter sticks in reverse
So to answer everyone's first question. Under the hood linkage checks out. Cables are good. Calbration for the cables also checked good. This is the shifter itself has become almost impossible to pull up out of reverse. I dont see anything out of place when i pull the boot. All other gears are just fine.
bob022004 is offline   Reply With Quote
Old April 24th, 2019, 10:26   #2
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
Does it make a difference if the engine is turned off?
I have a Skoda with a 6 speed that sometimes is hard to get out of first, I've checked everything and it's the clutch pedal itself that binds a bit. Just enough to not release the clutch all the way, so when you depress it it doesn't have full stroke on the clutch master cylinder and that causes the hard to get out of gear situation. I don't understand why the gear is easy to engage but hard the other way but when I put a dab of grease on the pedal it worked perfectly for a year and has now started to act up again.
Check if you can lift the clutch pedal further when it is released.
nokivasara is offline   Reply With Quote
6 Speed shifter and H7 LED Headlights for 2010 cookie88 Private TDI Items for Sale/Wanted 2 December 12th, 2016 10:42
2001 Jetta 5 speed reverse problem ghohouston VW MKIV-A4 TDIs (VE and PD) 3 September 17th, 2013 07:06
Shifter Questions (Reverse Lockout and Aftermarket Shifter) jesselyb VW MKIV-A4 TDIs (VE and PD) 5 May 4th, 2013 08:24
2010 Golf Mk6 Tdi Dsg shifter + shifter mechanism for sale mr_diesel Private TDI Items for Sale/Wanted 2 May 13th, 2012 18:40
Could a broken reverse shifter actuator snap the main shifter cable? kilimats TDI 101 0 October 20th, 2009 19:20
Page generated in 0.11483 seconds with 12 queries
[Output: 52.96 Kb. compressed to 48.93 Kb. by saving 4.03 Kb. (7.61%)]
