To buy or not to buy?
TDIJettaz
Grand Rapids, MI
'14 JSW, '02 JW
I have the chance to buy an '06 BRM Jetta with 207K. I don't know when the TB was replaced, there is a rubbing noise in the engine somewhere at idle, and brakes may have some issues too. I have pasted the results of my Vag-com scan below. Someone please tell me if the results show any major problems. I scanned the engine, transmission (No faults), brakes, electronics, and instruments (No faults). Also, the idle speed is at 840/min which seems a little bit low to me.
___________________________________
Tuesday, 28, July, 2015,18:22:01:32264
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 03G 906 016 AC HW: 028 101 223 9
Component and/or Version: R4 1,9L EDC G000DG 7551
Software Coding: 0050078
Work Shop Code: WSC 00066 000 00000
VCID: 64CDB249A7409E9
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Mileage: 331314 km
Time Indication: 0
Date: 2000.00.00
Time: 01:31:39
Freeze Frame:
RPM: 2205 /min
Speed: 105.0 km/h
Temperature: 34.2°C
Absolute Pres.: 1193.4 mbar
Mass Flow: 41.24 g/s
(no units): 2.59
Temperature: 84.6°C
Readiness: 0 0 0 0 0
Tuesday, 28, July, 2015,18:37:30:32264
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Control Module Part Number: 1K0 907 379 K
Component and/or Version: ESP FRONT MK60 0104
Software Coding: 0021122
VCID: 3A712C317544B89
3 Faults Found:
00493 - ESP-Sensor Unit (G419)
014 - Defective - Intermittent
00495 - ESP-Sensor Unit (G419); Supply Voltage
012 - Electrical Fault in Circuit - Intermittent
00778 - Steering Angle Sensor (G85)
Tuesday, 28,July,2015,18:27:06:32264
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 1K0 937 049 C HW: 1K0 937 049 C*
Component and/or Version: Bordnetz-SG H34 0803
Software Coding: F4098E02400418000014000000140000002077035C
Work Shop Code: WSC 00000 000 00000
Additional Info: 1K1955119B Wischer VW350 012 0401 1K0955559M
RegenLichtSens 005 0605
VCID: 2F670D65BE066D1
5 Faults Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
01598 - Drive Battery Voltage
000 - - - Intermittent
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
01501 - Bulb for Blinkers; Rear Left (M6)
JETaah
Vendor , w/Business number
mi 48836
If there is no mention of camshaft work, flywheel, EGR cooler, and maybe the turbo you can count on them being an issue. I'd say camshaft for sure.
You can add the above stuff you mentioned to that list.
deeslman
Newfoundland, Pa.
2005 punchbuggy 2006 jetta
All about dollars...........
If you can fix yourself. Less dollars
If car is clean and price seems low enough.
GreenLantern_TDI
Iowa
2015 GOLF SEL
Wouldnt even consider it for more than $2500 without reciepts for work done. As mentioned above this car will need alota $. You may if nothings been done be in the $4-5k range after purchase.
