dkuster
I did my first 5,000 mile oil change, and I was
going to replace the oil drain plug with my new
VDO oil temp. sender.
Unfortunately, the VDO sender is an "M10x1", and
the oil drain plug is a much larger diameter.
I've heard the oil drain plug is the best place
to take the oil temperature. What am I missing
here?? Did I get the wrong sender?? Is there
an adapter of some kind that I need? Or should
I just use M10x1 tap by the pump at the end of
the valve cover? (My '03 Golf doesn't have the
extra tap on the oil filter housing).
Any help would be appreciated!
