neilcaruana
Hi Guys,
Yesterday I have serviced my Car AC, this was done with an automated AC machine which checked for gas leaks, cleaned the system, replaced oil and filled the system with 134a gas. Everything went fine and the AC was working again we then measured the output air temperature which was reading 10-12 degrees at idle. After that I went for a 5 minute drive we check it again and it measured at 7-8 degrees after it was back on idle it was back to 11-12.
To give a small background I got the car from the UK (I live in Malta) and the AC was not working at all and I don't know when it was last used, this was due it was empty from gas and the compressor was not kicking in for obvious reasons.
Are these air temperature within normal standards ?
Your feedback would be of great use. Thanks.
