Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old January 3rd, 2020, 11:46   #106
fkoca5055
Originally Posted by Wacholek View Post
@fkoca5055
Where did you get those requests? 22114F, 22178C.
I think I will also work with arduino. It has no limits compering to Torque. At least until I will talk to its creator.
Probably you already have the basic knowledge about the ELM327, but this is nice info for start:
https://glmsoftware.com/documentatio...luserguide.pdf
https://www.scantool.net/scantool/do...reliminary.pdf
I think magic point is before sending requests use ATSH 7E0 for 11bit can network then use your stand or NON-stand PIDs
fkoca5055 is offline   Reply With Quote
Old January 14th, 2020, 12:07   #107
fkoca5055
Default dpf level
by the way I finished my project for Golf 7 1.6tdi (Soot mass calculated and DPF level added)
Old January 14th, 2020, 17:56   #108
Diesl
Very nice! Which program is that in?
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old January 14th, 2020, 18:08   #109
Diesl
Hi Fkoca! I'm not near my diesel right now. Are you saying that I could send this ATSH 7E0 command from inside Torque, and then access special VW variables? Or would one have to send the command outside of Torque?
Old January 15th, 2020, 09:49   #110
fkoca5055
I used esp8266+hc-05+ILI9341 lcd+LDR (for auto brightness) and Arduino IDE
https://github.com/fkoca5055/obdESP
Old January 15th, 2020, 09:52   #111
fkoca5055
I didn't tried with Torque app, but it worked with ELM obd terminal
Old March 22nd, 2020, 17:03   #112
coolvdub
Fuel Economy: 54.7 Best so far
Update 2018-2-15: after getting the emissions fix for my 2012 JSW TDI, the R49/R50 formula showed the same behavior that Mr.Beeblebrox above saw for his Passat, so I tried out his R40/R41 shift, and it works.
2013 JSW, I used the original formula and got an extraordinarily high reading, used the above referenced shift values and am getting closer to VCDS, but still off though.Torque is showing 23.9 grams soot while VCDS reports 6.9 grams soot and 18 ml oil ash. Looking for ideas if anybody has one.
SMF, PD150 Intake,VNT-17 with PP764's with more to come
coolvdub is offline   Reply With Quote
Old March 22nd, 2020, 21:26   #113
Diesl
I think there are computed and 'measured' (also computed, but differently) values, and switching from the r49/50 to the r40/41 location also switched methods, I'm guessing. If you have access to VCDS, you should be able to sort this out. Please let us know once you figured it all out.
Also, torque/OBD shows the max value for quite a while (70 miles?) after a regeneration; maybe VCDS is already showing the new value.
Old March 23rd, 2020, 16:39   #114
coolvdub
Diesl,
Thanks for the response, I was hoping you would see this. The long delay may be correct as the last regen was 10Km ago or 6.214 miles according to Google. Checked with VCDS today and this is what I got.
Monday,23,March,2020,15:28:33:09433
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4508.4
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 20051 Repair Order:
Address 01: Engine (03L 997 030 E)
15:28:12
2.0 Requested Regenerations
18 ml Particle Filter Oil Ash Volume
Particle Filter Carbon Mass (spec.)
Particle Filter Carbon Mass (act.)
2.2 l Fuel Consumption Since last Regen
10 km Mileage Since last Regen
132.0 Time elapsed since Regeneration
7.8 Soot Load(g) Calculated
0.0 Soot Load(g) Measured
Not really driving now since I am on leave due to covid-19 until further notice. Otherwise I drive over 100 miles a day.
Water Level Sensor False Reading vwfern VW MKIV-A4 TDIs (VE and PD) 6 November 24th, 2013 21:10
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 12:44
Messing with the Air Flow Meter Reading for tuning and to help combat soot? Possible? pietch TDI Power Enhancements 2 September 14th, 2008 03:57
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 05:26
SOOT LOADING LEVEL IN TDI OIL SkyPup Fuels & Lubricants 27 November 24th, 1999 11:19
Page generated in 0.14813 seconds with 13 queries
[Output: 98.00 Kb. compressed to 84.53 Kb. by saving 13.48 Kb. (13.75%)]
