DPF LIGHT...no faults
gsms
Calgary, Alberta
2006 TDI ...sold. 2009 TDI CR DSG
I have read on this forum and on others from 1pm yesterday until 5pm. I have a Vagcom, and have tried all the fixes and tricks that are associated with it. So here it is, I admit defeat and have to get the experts involved.
I had a standard run of the mill DPF light come this morning. I drive long distances every time the car runs, I have forced 2 regens, and there are no associated thrown codes, in fact there are no codes at all. The car has approx 182000 km’s on it.
I have had the light come on once a few years ago, the procedure in the manual to drive at a higher RPM fixed it.
Nothing I have done today has helped. Could the DPF need to be replaced? Seems like low mileage for it to fail.
Any help here guys would be greatly appreciated.
Car is a 2009 TDI DSG- 182.000 km’s
Particle filter oil ash volume is 120 ml
Particle filter carbon mass is 3.0
Particle filter carbon mass measured is 0.0
Is it normal to get the solid DPF light with no codes?
What should I attempt to do to get the light out?
The above numbers mean nothing to me..... the 120 ml I thought was maybe high. But from reading tons of other threads, maybe not.
Thanks guys!
gsms
Calgary, Alberta
I did a new scan today and forced another regen....it didn’t need it but I thought I would see if the light would go out. It didn’t.
I am convinced that the DPF is totally fine. The numbers support a healthy not worn out filter, as well as the fact that there are no codes whatsoever.
So, is there anyway to disable or turn off the Dpf symbol on the cluster?
I would not leave it that way without continuing to scan and monitor the Dpf.
I just can’t stand driving a car with a light on that’s not supposed to be.
meerschm
Fairfax county VA
2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
If you did a full auto-scan, and no problems,
and no OBD codes, this seems unusual
you can probably look for the instrument panel controller and operate the light manually to make sure it turns on and off.
If you want to post the results of an auto-scan, go advanced,
and with the scan output pasted into the window and with the body of text selected, push the
button
Code:
Like this
gsms
Calgary, Alberta
Yes, I agree that it’s unusual. I have also spoken with other TDI gurus, as well as
engaging in the other forum. Some say it’s unusual, others say it can happen.
I will try to post a full scan here later today.
Andy_2009_JSW
Atlanta, GA
2009 Jetta Sportwagen TDI (DSG)[SOLD BACK], 2012 Golf 2.5L Gasser (5MT), 2017 Alltrack S (6MT)
Agreed, seems odd and unusual.
Your TDI didn't by chance have any software updates done to it in the past year or so (dieselgate related), right? Just speculating that VW could have put [new] code in there that could be turning the DPF light on once the total ash volume reaches a certain level. You'd think it would have some sort of associated code thrown though if they were going to illuminate that DPF fault indicator.
Anyone know if there are any folks out there that "got the fix" (software updates) and that have an ash volume reading >= 120ml?
J.Harrison
Annandale, VA
2010 Jetta sedan, 2003 Ford Excursion 6.0
Im currently in the same boat. Was there any resolution to this?
Here is the latest auto-scan
# Saturday,08,September,2018,10:11:07:22809
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: 3VWRL7AJ3AM112771 License Plate:
Mileage: 161870km-100581mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ3AM112771 Mileage: 161870km-100581miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 08829 002 1048576
VCID: 36632CFC411E64F4CD-8062
1 Fault Found:
006744 - Unknown Error Code
P1A58 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 161873 km
Time Indication: 0
Date: 2013.01.29
Time: 10:04:51
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Pressure: 992.2 mbar
Temperature: 22.5∞C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 47.7∞C
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9037
Revision: 51112 Serial number: 00001002091702
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 2541FBB0ECB81F6C74-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492300FC881202EB921A0042310000
VCID: 7AFBF8CCF586409469-802E
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E1EBF0D4982FEC04-8020
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 2129
Revision: BI111001
Coding: 2D200B3E902F3EE4800800854000000401000086510085605C8020000000
VCID: 377D21F886149DFCD6-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 11031 21 0512
Coding: 009795
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02EMYD
Coding: 0012340
VCID: 6ED3C49C79CE1C34C5-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4E4246218
Subsystem 3 - Serial number: 6342MSME4F422753E
Subsystem 4 - Serial number: 6351HSME1F6317112
Subsystem 5 - Serial number: 6361HSME1F4531377
Subsystem 6 - Serial number: 63727SME1F7F137CL
Subsystem 7 - Serial number: 63827SME1F7F000ED
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001831
VCID: 76E3ECFC019E24F40D-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 271D00
Shop #: WSC 00066 123 00148
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 346716F49F6276E4F3-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 270110F2002111
Coding: ED807F07001602001002
VCID: 69D9B7804020FB0C90-803C
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4V1D05
Coding: 0000004
VCID: 3C773ED47F32BEA43B-8068
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBC88C8D26F01499-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000525088
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 275DF1B85EB40D7C46-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004699681
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31691FE0A87043CC98-8064
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000544298
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285FF28453AA02044F-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004709723
Coding: 000490
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6253873
Coding: 0000040004000A
Shop #: WSC 21862 418 140358
VCID: 46835C3CF1FEF4745D-8012
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Time Indication: 0
Date: 2013.01.29
Time: 07:41:56
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
1 Fault Found:
02904 - Hard Warning 3
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 157139 km
Time Indication: 0
Date: 2012.11.28
Time: 21:38:38
Freeze Frame:
Text: 3445723969
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 23.2∞C
Text: 00
Speed: 38.0 km/h
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668150895
Coding: 0A00000000010100
Shop #: WSC 01357 011 00200
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 326B10EC657678D4E1-8066
3 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 8
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 161846 km
Date: 2018.09.07
Time: 17:39:11
End-------------------------(Elapsed Time: 02:28)--------------------------
k3ys3r_soz3
Vancouver, BC
2010 Golf Wagon
I know this is an oldish thread but I am just wondering if anyone found out if there was a resolution to this DPF light issue as I am having the same problem now. I had the modification done in August 2018 and just had my DPF and EGR filters replaced plus my intake manifold changed this week. On my way home from the dealership after the service was performed my DPF light came on and my car seems to be DPF regening all the time now and it smells worse than usual during the regen. Wondering if there is anything I can do to get rid of this DPF light with my VCDS. I was told by the dealership that I would need to drive my car on the highway for at least an hour and a half to get rid of the DPF light. Not sure if I buy this resolution... wondering if this makes any sense having to do a regen on a perfectly brand new DPF and EGR filter - something just doesn't add up.
Gloucester, MA USA
'13 JSW Tdi, '06 A3 3.2Q
I am dealing with this now in our 2013 TDI sportwagen.
We had the "fix" done at 94K miles.
At 103K miles, the dpf light came on. Dealer claimed driving style not optimized for regens. For the record, this car drive in and out of Boston, commuting highway/local, 70 miles per day, 5+ days per week. Dealer (Colonial, Medford MA) charged 2 hrs labor to regen. BS.
123K miles, dpf light back on. VCDS says code P1A58 "unknown "
Back to dealer, who claimed to drive it 45 min at highway speeds, which reset the light.
129K miles, dpf light back on. Updated VCDS version, reads same P1A58, but now VCDS knows that is the code for NOx Catalyst regeneration required. NOT THE DPF!
Soot load at 5 grams, so DPF is fine. Why wont a NOx cat regen? Why DPF light? maybe because there is no post fix "NOx" light?
Have not gone back to Colonial yet, looking for other info to make my case that this is an emissions warranty problem, not due to sub optimal driving style.
Bottom line, P1A58 is a NOx catalyst non regen issue, not a DPF regen issue.
Gloucester, MA USA
Update. Code cleared from driving, but came back on in the winter, and still on.
Definitely a problem with the deiselgate mandatory fix. I dont have the energy to fight the dealer over it.
VW wins.
