steve b
Hey folks,
Hopefully you can give me a few pointers here. Here is my situation.
Question 2: How do you test the wastegate valve to see if it is moving?
Question 3: Boost gauge - Where does this hook up and what info will it tell me?
Any recommendations are appreciated.
Steve
- 1997 A3 175,000 miles
- running good but saw that the intake needed cleaning (preventative maintenance)
- cleaned the intake (this is my second cleaning since owning the car)
- car ran really nice for about a week and then I went into limp mode.
- VAG-COM 5.04d - said I had the 575 intermittent different pressures etc.
- When the car ran good I could hear a low toned whistle when you accelerate quickly.
- I seem to be getting more exhaust gases up under the hood and into the hvac system
- Took off the turbo/intercooler hoses and inspected for splits/problems etc. - none found
- Replaced the N75 valve - still went into limp mode
- Put a pry bar on the waste gate actuator and it seems to have lot of spring pressure but it would move
Steve
