Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old August 19th, 2018, 22:47   #1
DezlDan
DezlDan's Avatar
Fuel Economy: 800 km per tank (avg)
Default Foot Activated Touareg Hatch Problem
My Touareg has the foot activated rear hatch, where you stick your foot under the bumper and the hatch opens. Iíve only had the car for 2 days, and the feature worked, but today it went funky. The hatch will respond to the foot, and the taillights will flash, but the hatch only unlocks and wonít actually raise. The hatch opens using the key and the inside release, so Iím thinking that perhaps the computer just needs to reset itself. Anyone else had this? What was your experience?
05 Passat Variant TDI - Chainless: 2012-06-30 (Extended Warranty)
"In a world of shrinking sedans, it's more fun to take the wagon."
DezlDan is offline   Reply With Quote
Old August 20th, 2018, 22:27   #2
DezlDan
DezlDan's Avatar
I fixed it. Never mind.
Old August 21st, 2018, 04:14   #3
showdown 42
Just curious, what yr is your Touareg? I have a 2016 and don't have foot activated lift for tail gate. Unless I need to do something to get it going. It's new to me. Thanks.
showdown 42 is offline   Reply With Quote
Old August 21st, 2018, 07:33   #4
DezlDan
DezlDan's Avatar
Mine is a 2014 Execline, and it has a lot of little things installed over some of the lower trim levels of the same year. Itís a pretty neat feature, but not crucial.
Old August 21st, 2018, 08:44   #5
KITEWAGON
KITEWAGON's Avatar
Same here, but I have never been able to figure out the foot hatch function. I think it maybe has worked once ever and I finally stopped dangling my foot at it like a crazy person.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old August 21st, 2018, 10:06   #6
DezlDan
DezlDan's Avatar
I do it on the left side, and you have to thrust your shin toward the rear back up sensor (getting quite close) while slightly shoving your foot underneath. Then, voila!
Old August 21st, 2018, 19:59   #7
Yeti35
Yeti35's Avatar
I would rather have the button on my FOB that opens it every time rather than doing a silly dance to get it to open.
2010 V6 TDI Touareg, Lux,Tech, Air and hitch
Yeti35 is offline   Reply With Quote
Old August 21st, 2018, 22:56   #8
DezlDan
DezlDan's Avatar
I have that too.......and a open / close button on the driver’s door panel. 3 glorious ways to open and close my hatch, and a 4th if you also count manually.
My hatch problem fixed selway VW MKIV-A4 TDIs (VE and PD) 0 February 6th, 2018 12:04
Hatch problem. Stephen03tdi VW MKIII-A3/B4 TDIs 1 August 5th, 2017 11:35
Touareg Rear Hatch Operation - hate it GEO8 VW Touareg TDIs 2 February 25th, 2015 19:13
no sound when switched on door activated for hatch mittzlepick VW MKIV-A4 TDIs (VE and PD) 10 May 16th, 2008 17:12
Hatch problem... mtltdi Upgrades (non TDI Engine related) 17 August 27th, 2006 20:26
Page generated in 0.17251 seconds with 11 queries
[Output: 89.05 Kb. compressed to 76.67 Kb. by saving 12.38 Kb. (13.90%)]
