I've been hearing a rough bearing sound from i believe my transmission. As the car is decelerating, with the clutch peddle pushed in and held in, i shift into 2nd gear and hear a rough bearing sound. if i shift into 1st rough bearing sound gets louder and continues until i come to a complete stop. the sound dimishes as vehicle speed drops. Since the clutch peddle is pushed in, the engine, flywheel & pressure plate is turning at idle speed, the clutch disc would be turning a the same speed as the trans input shaft, again the rough bearing sound gets louder and faster has i shift into 2nd then 1st (again clutch peddle is pushed in the whole time).
I've drained the transmission and replaced fluid (thru the reverse switch hole i added almost 2 qts Redline fluid from IDParts), drove for 3 weeks, sound remains. Now i seem to hear a sound at highway speeds when car is in 5th gear. Drained fluid again, there seems to be a metal looking scheen on the fluid. No large metal particles have been found in the fluid. Running a magnet thru the fluid does not show any metal.
Transmission is now removed, I was thinking of replacing it, but everyone says these gearboxes hold together. 210,000 miles currently on the car, all of which are highway 80mph speeds. i removed the trans cover and inspected the gear faces i could see. all looked good. i removed the shifter and inspected gear faces. one gear tooth had a small chip on the end, but all gear teeth faces look very good. i was thinking of cracking the case to inspect various bearings...
if i crack the case apart do i need to worry about anything falling out of place? Syncronizers, various parts and pieces...
is there any thing special i need to worry about?
do i need any special tools to do so?
is there a GQQ transmisison rebuild manual out there anywhere?
