TDI me
I will need to remove my carpet and replace it, has onyone done this? Any recommendations as to what tools I will need, tips, tricks? Maybe a list of what has to come out? I didn't see it in the HOW TO section. Thanks
I did an interior swap years ago. Managed to do it in about a day. There is a lot of stuff to remove but it isn't that bad. I remember a lot of people talking about cutting the carpet around the radio brackets. To be honest, taking out those brackets wasn't nearly as difficult as anything else required to do the job and even though it did add a bit of time, it wasn't much.I will need to remove my carpet and replace it, has onyone done this? Any recommendations as to what tools I will need, tips, tricks? Maybe a list of what has to come out? I didn't see it in the HOW TO section. Thanks
Once you get the screw out press on it (like you’re in the seat with your foot on it) and the slide it up like you trying to get it to go up into the dash. It will make sense when you’re doing it.Easy job. There's a trick to not breaking the clip underneath the dead pedal... I think you need to push it forward, not pull it straight up after you unscrew it.
junkyard pick and pullWhere can we buy a replacement carpet ??
