dgoldfarb1957
I would like to know where part 8Z0 820 535 (temp sensor) that fits into radiator support bracket 786 035 730 C is located on the vehicle. A picture would be helpful. This is for a 2010 Jetta Sportswagen.....Thank you.
I found the answer in previous posts. I should have performed a search prior to posting. The answer is the sensor appears to fit into the radiator support bracket on the driver's side in front of the radiator below the bumper.
