325isbimmer
Firstly, I'd like to say my hellos to everyone here. I've been browsing this forum since before I purchased my first TDI back in November 2010. A 2006 Jetta (Canadian Highline) with 210,000km. The reason for the high milage purchase was price for one and partially the options (mem. seats. MFD+, steering wheel controls, Rear sunshade) but mainly, after searching high and low (2009 models inclusive) this car had been meticulously maintained in both appearance (at least as far as canadian winter driven cars go) and mechanical aspects. The previous original owner had all of the VW dealer performed service records. Now that being said I realize that even so that is not enough in some cases, but after looking over the car on two separate occasions, and taking the price and options into consideration, I decided to go with this vehicle. I'm now at 243,000 km (~150,000 Miles) and still happy with my choice. The car runs very well and is still in great shape, withholding a couple of issues.
Although I'm relatively new to this seemingly more complicated TDI world, I have been working on all things mechanical since I was old enough to ride my first dirt bike (and quickly learned that if you want to ride/drive something, inevitably you will need to fix it) After highschool I worked professionally as an auto mechanic for 5 years, at which point I went back to school for mechanical engineering. I'm now in a career as a mechanical designer for companies who make automated assembly/welding machinery for the automotive industry. So though I'm far from an "expert" I'd like to think my mechanical aptitude is above average. I've tackled just about every job you can name on a vehicle from a complete restoration (94 BMW 325iS, still in progress.lol) to engine swaps to regular maintenance as in timing belt on 04 A4 Quattro. Anyways, enough about me and onto the issues at hand.
Like I said, the car seems to run great expect for one thing. It has this stutter that comes in at around 1800 RPM, which seems to be more pronounced in 1st and 2nd gear. For example as you take off from a stand stand still, ease out of the clutch then get on the gas moderately, you can hear the turbo building boost and then as comes near 1800 RPM the car stutters as if that throttle plate before the EGR valve assembly is closing and opening a few times within a couple of seconds. Then a big puff of black smoke and off she goes with gobs of torque through the rest of the revs. If you rev it out to 4000 RPM (which I don't practice doing too often) and get into the next gear then you avoid that 1800 RPM spot and the hesitation is not felt in the following gear. However it does do something similar in 4th and 5th gear (again at that magical ~1800RPM mark) if you're cruising along at a steady speed, not accelerating nor decel, but if you go from a slight decline to incline (as in the load on the engine changes) it will "buck" a few times and then you hear the turbo build boost again and all is well. Both of these situations can be helped (which I've learned to do overtime) if you "feather" or slightly "pump" the gas pedal. As if you had a nervous twitch. easier to do when going from stopped start with the stutter as opposed to the buck in 4th and 5th. I've been chasing this issue since after I bought the car and seemingly so has the previous owner as I can see by the brand new shiny EGR valve assembly (probably replaced under warranty since there was no record for this ) I've done such things as check for the VNT valves movement (seems to be fine) Replaced the N75 Valve, Unplugged one at a time and both the EGR valve and "throttle flap" plugs with no success to the issue at hand. I believe this "flap" I keep referring to is the Anti-run-on valve? One thing I have noted overtime while searching for the cause is when I turn the car off You can hear that flap (or could be the EGR itself) cycle a bunch of times. Which reminds me I guess I should take the intake boot before that off and have a look to see if it is in fact that flap. I'm not sure if this is supposed to be or if something in the electronics is telling the EGR system to cycle a bunch of times,
I could probably go one describing the little details I've noticed and think may or may not be related to this problem but I'll stop here and let you guys have a read at what must be a novel by now.
Thanks for taking the time to read and any input or suggestions is appreciated. Also I look forward to many more (hopefully shorter) posts on this forum
Cheers!
Andre
Cheers!
Andre
