'86 2WD Toyota, 1.6TD to AHU
Rockwell
Manchester, NH
2003 Jetta TDI (R.I.P.), 1.6TD Toyota pickup, 2011 BMW 335d, 1996 Passat TDI
Post pics as you go, I need the motivation. I remember a papasmurf from my Samurai days on a couple of Offroad forums.
papasmurf
Orlando
1997 jetta tdi, 2004 passat sedan tdi, 2005 passat wagon tdi , 2005 passat sedan tdi
Yeah that would not be me. I will, I was just hoping you would have that crazy speed machine done by now lol
Rockwell
Manchester, NH
Tinkering with this project again.
I’m going to use an external lift pump, can I leave the fuel filter under the hood or would it be better to install it between the pump and fuel tank? Should I cool the fuel returning to the tank? There is plenty of room for a cooler.
Motohead1
charlotte
2002 bug+telephone pole
check the type of pump you will use. old 12valves used a crappy external pump that would die. latter they changed to an intank pump that pushed threw the filter. Im running one of those in my tank works great and I am pushing through the VW filter. And as long as your tank is a good truck size you wont need a fuel cooler.
Rockwell
Manchester, NH
It’s a decent Carter pump, I just don’t want to relocate the filter to under the bed
papasmurf
Orlando
I don't believe I ever saw what your motor mounts looked like. Did you fabricate your own or get some from a samurai place?
Rockwell
Manchester, NH
I made them, pretty basic. I figured when I eventually get this running I will make up some hydraulic mounts if the vibes are too much
Rockwell
Manchester, NH
Plugging away at this again. Getting a code for implosible (sp?) signal for the brakes and a blinking glow plug light. When doing my wiring, I wired a relay to toggle a ground between the 2 brake inputs on the ECU when the brakes are applied. Doing a little research indicates a burnt out brake light. Should one of those brake inputs to the ECU have a resistor to simulate a bulb present? Should one of them have a voltage going to it instead of a ground?
CasaEd
Portugal
VW Passat TDi B4, VW Passat TDi B4 GL, VW Passat B3 PD AWX Conversion
Brake Pedal Position (BPP) Switch ECM Pin 32- Ignition OFF Brake Pedal Released 0 V
Brake Pedal Position (BPP) Switch ECM Pin 32- Ignition OFF Brake Pedal Depressed 11-14V
Brake Pedal Position (BPP) Switch ECM Pin 65- Ignition OFF Brake Pedal Released 11-14V
Brake Pedal Position (BPP) Switch ECM Pin 65- Ignition OFF Brake Pedal Depressed 0V
This is for the 038906012xx Style ECM.
You can use a single brake switch with a 5 pin relay, as that is what I'm doing on the B3 Passat I have.
Rockwell
Manchester, NH
Good info! Thank you.
Don’t plan to use clutch switch. Should the ECU input be left open or 12v?
