mwolf5141
What fluid should I use & where is the fill?
Any pdf's with pictures on this?
The 2005 is a split year on the Jetta (unless it is a wagon) and they use two totally different automatic transmissions with totally different fluids.mwolf5141 said:What fluid should I use & where is the fill?
How do I tell which one I have?oilhammer said:The 2005 is a split year on the Jetta (unless it is a wagon) and they use two totally different automatic transmissions with totally different fluids.
If it is an early 2005 sedan or a wagon, it uses the Jatco 09A 5 speed automatic that uses G 055 025 A2 fluid. If it is a late 2005 sedan it uses G 052 182 A2 fluid.
So you have an A4 platform car, with the 09A trans.mwolf5141 said:I guess mine looks more like the early one. Though not as fancy as that one.
Should I attempt fluid service myself?oilhammer said:So you have an A4 platform car, with the 09A trans.
