I am going to be replacing the camshaft and lobes and everything else that goes with it and was wondering what tools I am going to need and if there is somewhere I can rent them because I'm pretty sure autozone won't have them. Thanks in advance.
Bump for a great guy: Frank06. I bought his camshaft kit and my car runs better than new!Not that I'm aware of. Just PM him or call directly... great guy to work with and his kit guarantee is the best: 417-232-4634
To remove/install the cam hub center bolt, get 2 longer cam sprocket bolts and figure out a lever that will sort of wedge between them to hold the cam from turning while you loosen/tighten the center bolt. Much easier if the sprocket is not installed.How would you suggest tightening the center bolt once the cam is installed in the car without the VW counter tool. Im working on a BRM motor and have the cam installed and everything torqued down. However im weary of tightening that bolt without the tool from keeping the pulley from moving. What if i tighten it after the belt is on?
Can you please specify what tools those are? The "$30 crank indexing tool" and "letter size "A" drill bit". Where did you buy them? What's the part number or something to identify them and look on eBay.The only special tools I needed to change the cam and T/B were the $30 crank indexing tool and a letter size "A" drill bit for indexing the cam. With a little ingenuity, there is no reason to spend hundreds of dollars on special tools.
Crank tool:Can you please specify what tools those are? The "$30 crank indexing tool" and "letter size "A" drill bit". Where did you buy them? What's the part number or something to identify them and look on eBay.
@Frank06 is great! His guidance on which kit of his to go with, the why on his oil preferences, ordering, shipping AND answering the little questions that came up while doing the job SUPER fast, even in the evening.Bump for a great guy: Frank06. I bought his camshaft kit and my car runs better than new!
