Vangruver
today i was driving and was periodically checking the scangauge,
then all of a sudden the backlight started flickering
i didn't know what was going on with it, so i unplugged it from the obd port, and put it back in, and found that it wouldn't even power back up.
so i carried on with my drive and thought to connect it back up after.
connected it back, and nothing powered up, no backlight nothing.
did a quick google search on a possible cause, as well read the owner manual still in the passenger door card, and found that it could be becuase a fuse powering the obd port may have been blown.
quickly checked all fuses and nothing was blown.
come home a few hours later, and discovered that it would power up, but flicker AGAIN, and then no pixels would display, but only the backlight.
I've sent an email out to scangauge to see what possible problem this could be, but i thought, why not see if anyone else has had this surface with theirs.
any insight would be appreciated.
