Old January 5th, 2018, 23:07   #16
Mike in Anchorage
Mike in Anchorage's Avatar
Originally Posted by orlando View Post
Oh, so it really WAS a stupid question! Sounds like CEL is generic for what VW calls MIL. Yes, I wouldn't be surprised if it's illegal to sell the car here too (though we have no emissions inspections). I don't trust the dealer at all, which is good reason not to buy from them, though I think they're hurting themselves with such carelessness and if I can get a good enough deal. . . .
Your name is Orlando and you live in Dystopia? That doesn't help us to know what is a normal temp range for your location.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old January 6th, 2018, 09:07   #17
orlando
Ha! It's FREEZING here (Columbus Ohio) and has been for two weeks. What could be more dystopian than the midwest?
After a month of following prices and test driving, I decided not to buy one of the 2015s. Two GSWs with the SEL trim dropped under $18K (!) here (and two others dropped to ca. $19K), but the both had an MIL with emissions-related problems. (I confess I was going to buy one of them anyway if it came down another $500, but it sold first.) Now none are for sale in central Ohio for under $20K.
orlando is offline   Reply With Quote
Old January 6th, 2018, 10:02   #18
showdown 42
I expect a large majority of VWs with ad blue systems fail in the heater dpt. It is a know problem. My TREG tdi ad blue heater failed at 35K miles,replaced by VW under good will. Light just came on for a few days at 55k miles. I may be going back for another replacement. No big deal as long as they pay for it. I do have a 100m 10yr extended warranty which has been very handy.
showdown 42 is offline   Reply With Quote
Old January 6th, 2018, 10:35   #19
Grigg3
Where is the heater, how easy to change, and how expensive?
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old January 6th, 2018, 13:46   #20
Mike in Anchorage
I grew up in Waverly. Yeah, I know the freaking out every time there is 2" of snow.
FWIW, I have a 2015 that I bought in September and have been driving here in Anchorage since then. Yes, I have a garage, but it's parked at work in sub freezing temps all day and I have had no problems.
Good luck.
Old January 6th, 2018, 15:41   #21
manyVAGs
It really does not matter where it is because it is a free fix under warranty for 11 years or 162k miles if you had the emissions fix done.
manyVAGs is offline   Reply With Quote
Old January 6th, 2018, 21:25   #22
Grigg3
It matters for my own curiosity, and to learn more about these increasingly complicated cars.
Old January 7th, 2018, 08:20   #23
jjblbi
Fuel Economy: 41ish mpg post fix
If you have the ability to reset the code, do it. My '14 Passat SEL def heater threw the code a few thousand miles ago (135k now). I researched the least costly replacement (T-Reg part with harness mod) and decided to try resetting first. After two or three resets a couple of days apart no more code or dash light. We are in the middle of some of the coldest weather in years, single digit nights and teens by day. Indicated -4F on my commute last week.
Hope I haven't jinxed myself!!
jjblbi is offline   Reply With Quote
Old February 12th, 2018, 10:40   #24
fredthe
So the car threw the code again, just before we got the fix. I cleared it (since it was technically out of warranty at the time) and the dealer did the fix without any issues. It's now thrown the code post-fix and goes in tomorrow for repair. We'll see if they replace the AdBlue tank again, or check for loose connections. It seems that the code only show up in cold weather (which would make sense, since that's when it needs the heater.)
fredthe is offline   Reply With Quote
Old February 13th, 2018, 07:42   #25
740GLE
I think dealers charge around a +grand, parts are around 3-400, I believe the tank/heater/sensor/pump is located in the right rear wheel well area.
Old February 13th, 2018, 14:42   #26
fredthe
Originally Posted by fredthe View Post
So the car threw the code again, just before we got the fix...We'll see if they replace the AdBlue tank again, or check for loose connections.
And the dealer says the Heater isn't covered by the extended emissions warranty. On hold with VW cusotmer careless now.
Edit: VW confirms that the AdBlue heater is not part of "The entire exhaust after treatment system." They are going to talk to the dealer and see what can be worked out.
Old February 13th, 2018, 15:34   #27
fredthe
Originally Posted by b1jackson View Post
Is the ad blue heater covered under the extended emissions system warranty? The one offered by the "fix"?
Apparently not
Old February 13th, 2018, 20:30   #28
Lightflyer1
Lightflyer1's Avatar
Have you tried disputing it with them? All disputes are supposed to be resolved in favor of the owner. I would contact the Class attorneys and get them on it, maybe.
Old February 13th, 2018, 21:15   #29
fredthe
Not yet, I need to see what they come back with. But yes, I do plan to dispute of necessary. I just need to have all the relevant documents ready to quote to them.
Old February 14th, 2018, 05:17   #30
740GLE
wow NOx related emissions components isn't covered by the EPA approved fix related warranty, that's a good one!!!!
If they are replacing heater cores under the extended warranties, yet not the any part of the DEF system that's just ripe.
Best of luck and report back the outcome.
UNOFFICIAL Adblue Heater Element Failure Thread dee74 VW Passat Family (NMS and B7) TDIs (2012+) 401 January 22nd, 2018 07:14
Do you need Adblue heater? bta 120 Ontario 17 November 13th, 2016 18:13
AdBlue Heater Failure and the Emissions Scandal lousyg VW Passat Family (NMS and B7) TDIs (2012+) 3 March 3rd, 2016 10:29
AdBlue heater roni024 TDI Fuel Economy 11 February 20th, 2016 18:32
Rats, wiring damage, AdBlue Heater failure White Passat VW Passat Family (NMS and B7) TDIs (2012+) 9 December 21st, 2015 05:39
Page generated in 0.20433 seconds with 13 queries
[Output: 131.75 Kb. compressed to 110.17 Kb. by saving 21.58 Kb. (16.38%)]
