Old February 13th, 2018, 19:07   #1
fairbanks
Default Fuel injectors nm?
I took out my fuel injectors, now I want to put them in, the torque wrench has weird numbers on it.
I have read that 22 nm torque is what I need but that's at the top of my scale on a Pittsburgh ratchet torque wrench?
I know this is just a simple misunderstanding.
Shine some light on this.
fairbanks is offline   Reply With Quote
Old February 15th, 2018, 08:41   #2
zzdiesel
Is your wrench 1/2 or 3/8 in?
zzdiesel is offline   Reply With Quote
Old February 15th, 2018, 10:16   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Every torque wrench has an effective range of measurement. The ideal usage places the needed torque in the middle 50%. Readings at the beginning or end of the scale are not as accureate.
Best to get a torque wrench where your needed torque is somewhere near the middle of its range.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old February 15th, 2018, 16:28   #4
Uberhare
Uberhare's Avatar
Fuel Economy: Depends on what I'm towing!
I have 3 different sized torque wrenches, and sometimes i wish I had a fourth.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
FS: common rail fuel pumps, injectors and fuel rails pghvdubguy95 Private TDI Items for Sale/Wanted 6 December 12th, 2012 18:03
Willie Run 2008 Needs Fuel!! TX NM WashBDTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 8 September 30th, 2008 12:10
Biodiesel fuel viscosity and fuel injectors aloser Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 December 7th, 2006 08:57
Bad Fuel Injectors, Nozzles or Mexican Fuel?? Yaco TDI 101 6 October 28th, 2006 06:30
Fuel injectors displaypack VW MKIV-A4 TDIs (VE and PD) 3 September 30th, 2004 19:05
Page generated in 0.13929 seconds with 13 queries
[Output: 62.78 Kb. compressed to 56.16 Kb. by saving 6.62 Kb. (10.55%)]
