Old February 7th, 2018, 14:02   #1
Jakub
Default Ahu turbo boost control question
Hi
I converted a 93 suzuki sidekick gas engine to a 1997 VW Jetta TDI alh. I had a code jump up and noticed that when Iím driving my boost stays constantly high as if the actauator never kicks in to let it out when it reaches to high and puts me in limp mode . The actuator moves freely and has no obstructions and seems to be set properly. What can I adjust to allow the actuator to open to allow boost out? Or do I need to get a manual boost controller ?
Jakub is offline   Reply With Quote
Old February 7th, 2018, 15:45   #2
Jakub
For some reason the code I get on vagcom is 000625 vehicle speed signal
27-00 implausible signal
Old February 7th, 2018, 17:13   #3
Mongler98
So it was working before right? Boost control is controlled by vacuum on the ALH and the n75 valve. Check your vac lines and pull a vacuum on the turbo actuator and check the n75 valve. It sounds like its the n75 or the controller within the ECU or some value its getting improperly and not letting it open to dump the exhaust waste gate open.
Old February 8th, 2018, 09:36   #4
Jakub
Yea it was working before or it appeared to be bec I didn’t get the code.
I was thinking n75 valve but it appears to be clicking away working.
Old February 8th, 2018, 10:31   #5
Mongler98
get a vacuum tester tool and test the actuator for leaks and im asuming that the vtn ring and blades are freely moving from your description. You go into limp mode so i would say most likly you have a vacuum leak or boost leak and its not closeing or its getting stuck open
Old February 8th, 2018, 14:42   #6
Jakub
I only go into limp mode on the highway going up a steep grade
I’ll check things
Old February 8th, 2018, 15:11   #7
Mongler98
are you sure your lines are good?
Old February 8th, 2018, 15:25   #8
Jakub
Well when I installed them with the engine everyting was new but I will check
The car makes boost just something doesn’t let the boost off it just continues to climb
Old February 9th, 2018, 06:45   #9
Mongler98
what lines did you use? OEM lines like supplied from IDparets.com lasts a a while, the hoses you get a auto stores last about 4 months if your lucky, ESPECIALLY in diesels.
the silicone high quality hoses on amazon last for near close to forever.
Old February 10th, 2018, 12:42   #10
Jakub
I used the braided black vacuum lines
Old February 10th, 2018, 16:00   #11
Mongler98
sounds like a bad actuator, ripped diaphragm, thats easily the 2nd likly issue. Have you checked the line going into the ECU? there is a small part of vac line inside the ECU.
Old February 10th, 2018, 19:50   #12
jimbote
jimbote's Avatar
if your engine is from a 97 jetta it's an AHU not an ALH. ... AHU uses boost (not vacuum) through the N75 to control the wastegate, so if you've plumbed it to vacuum that's a big problem...
jimbote is offline   Reply With Quote
Old February 10th, 2018, 19:55   #13
Mongler98
OH good point lol, i missed that one. HAHA, well it was working before, i think he is confused and does have a AHU so yea boost lol
OP can you elaborate for us what turbo you have on it and what engine please.
Old February 13th, 2018, 15:39   #14
Jakub
Right I acccidnetly wrote alh and tried to edit that but I guess it didn’t work.
Yeah it’s the Ahu.
The actuator seems to hold air
Old February 13th, 2018, 19:43   #15
Mongler98
yea, its all boost, 99% sure if your lines are good and your still having issue, take the ECU out, open it up and CAREFULLY replace the hose inside it.
Boost control question Jesse_Boyer VW MKIV-A4 TDIs (VE and PD) 2 December 25th, 2013 20:00
Boost Control Question Jeepmb TDI Power Enhancements 3 May 2nd, 2009 17:43
Turbo boost control hose, where? 97BlackTD TDI 101 1 July 14th, 2008 09:31
boost control question christi VW MKIII-A3/B4 TDIs 6 February 20th, 2004 07:36
Boost control question dtreid VW MKIII-A3/B4 TDIs 9 December 10th, 2003 06:02
Page generated in 0.12363 seconds with 13 queries
[Output: 116.10 Kb. compressed to 95.99 Kb. by saving 20.11 Kb. (17.32%)]
