Yes. You should check to see it there is a collapsed lifter.
With the engine warm, and the cam @TDC, and valve cover removed, you can push on the cam followers with a screwdriver or wooden dowel and 'feel' if they sink, are frozen or feel right. They should have a little bit of movement to them. 1/2 of the lifters can be checked with the #1 lobes "UP" and then, turn the crank until the #1 lobes are DOWN, and check the rest. I would guess one would feel particularly loose.
To remove the cam and check cam follower faces, loosen timing belt tensioner, remove timing belt from Cam Sprocket. Loosen the cam sprocket bolt by using a counterhold tool. Loosen the bolt a few turns and leave it in, for the moment. If you don't have one, we can supply any of the timing belt tools. There is a sprocket buster tool, but a small hole melted through the timing belt backing plate near the top of the hub of the sprocket will do the trick. We use a pencil soldering iron to do the job. Place a long, 1/4" punch through the hole, and smack it with a 5 lb mallet. Cheap and easy... Now you can remove the sprocket.
Remove vacuum pump. Loosen the cam cap nuts from cam cap 1,3 and 5, then incrementally loosen #'s 2 and 4. Remove cam caps. PLEASE NOTE THE DIRECTION AND LOCATION OF CAM CAPS!! The 1 and 5 can't be mixed up, but 2,3 & 4 LOOK IDENTICAL. Mark them or look for the #'s on the tops of the caps. Caps are not only fit for location, but they are also directional. The moon cut goes to the manifold side.
Now you can lift the cam out. Look at the tops of all the lifters to see if there is any wear in the tops. 'Bow ties' or straight lines on the lifters are indication the cam and followers are worn out.
We stock replacements or upgrade mod cam kits, timing belt tools and plenty of great hints and tips for our customers.
Questions? Let me know.
