Machineman
- Joined
- Aug 25, 2014
- Location
- ontario canada
- TDI
- 2007 RS4 Titanium 3.0TDI & 2013 Touareg TDI & B6 S4 BHW Swap Biturbo
Congratulations bobby thats impressive im so excited what size exhaust are you running ?
Custom pulley or someone offers these also?Sure. some run cp3, although smaller displacement, at 1:1 till 5k5 rpm.
No cp3 is smaller in diameter. But the cp4 has a 2 piece pulley so the idea is to make a new hub that fits the cp3 shaft and mounte the cp4 gear-piece
Thanks HannuImpressive results. You are in M550d balpark of rail pressure now
Lähetetty minun PLK-L01 laitteesta Tapatalkilla
63/56what is your major inducer mm on your turbine ?
Hi Bobby, can you say what part # the MAF is? Also do you know who could offer the adapter pipe solution?
Lol, I remember some time ago you were clearly convinced you didnt reach the limit of the stock MAF yet, but now you want to use biturbo oneHi Bobby, can you say what part # the MAF is? Also do you know who could offer the adapter pipe solution?
