TurboFromHell
- Joined
- Feb 20, 2005
- TDI
- Jetta, 2001, Green
I have 135k on my 2001 jetta TDI. At about 2800-3100 rpm on acceleration my turbo falls flat on its face. Check engine light comes on for a short period. Code P1557 appears and is not defined. Stealer advised "turbo Overboost" and scratched their head. Had no idea what could cause this. They replaced the MAF and Boost Pressure Reg. (n75 Valve) at the tune of $648. Still have the problem. Took to a "real" mechanic and had the intake pulled/cleaned. Had timing belt replaced (again). Also cleaned turbo intake and had adjusted to manu spec. Still have problem. After continous driving (15-30 miles) check engine light resets. Turbo acts fine. (additional note: when turbo falls out, turning key off then back on while driving releases turbo back to normal operation.) Desperately wanting issue solved have been trying everything besides replacing turbo to correct. Have been told turbo operates fine and there is something else causing problem. I have been dealing with this issue since about 70k miles, and it is progressivly getting worse, now when stopping the engine shudders like its going to die out but doesnt. I was told but the stealer my rotors were warped and I replaced front brakes. This did not change a thing. I have had this vehicle to several different stealers. I think they are all morans!!! "Any Suggestions??????
