Powerstroke9773
- Joined
- Feb 2, 2015
- Location
- North Carolina
- TDI
- 2002 Jetta TDI (totaled parts car) 2003 Jetta GLS TDI
Good afternoon all, I recently swapped engines in my 2003 Jetta to the one I had in a 2002 that it totaled. Prior to the swap when I would start the car and very rarely intermittently the ABS and Brake light will flash and I will hear a warning chime 3 times also my Trip meter and my clock on the gauge cluster would reset to 0 and to 1200 on the clock with the green car the radio would also reset to factory settings as if I pulled the ground off the battery and lastly if I had headlights on they would turn off for a second. Another issue I had was when I would go to start the car all power would die until I placed my foot on the brake then it would start fine. So during the swap I was hoping the new computer and gauge cluster would fix this issue. Turns out it didn't so I did a little bit of reading and found that there are 3 ground studs under the battery tray one for the negative battery terminal that also runs to the engine block, and 2 others with small brown wires on them. I cleaned the big one for the battery and attempted to clean the next one with 2 brown wires on I didn't do the one furthest outboard on the car. So all day yesterday I had no issue with the flashing power or the no power on start up. Today though different story I have the dash resetting the clock and Trip meter and I still have the issue of the no power when attempting to start. Weird thing is now the radio is staying at the settings I programmed into it i.e. the station isn't changing and the colors are the same. So question is, is this still a ground issue and do I need to clean all 3 really well or is there another ground for the gauge cluster I'm missing??? sorry for being long winded just a real pain in the A** especially for trying to figure out fuel mileage. I'm assuming one of the grounds I cleaned is the reason for the radio working properly. Any help would be greatly appreciated.
