The J
Ok, I took some videos last night of the car. Apologies for poor volume... this is a crappy cell phone, but it's much better than nothing.
Please pay attention to the noise I get after shifting.
It does it in all gears, no matter the rpm. It's a lot more audible at higher RPM so that's where I shifted (4k). But it's there even at 2500 rpm shifting from 1st to 2nd.
EDIT FOR MORE INFO: It happens anytime I let off the accelerator... so even coasting in gear it makes that drone noise. I should have taken a video of that, sorry. But it's the same sound.
EDIT FOR MORE INFO: I compared the injector tick with the ol' screwdriver to the ear method... injector 1 is noticeably louder than the others, and the Injector balance (group 13) shows that one in the positive, while the others are in the negative range. I'll see if I can get exact values.
ALH, 245k, stock except for some cheapo .205's (from original owner).
I do have a weeping EGR (recently started to weep). Cam and lifters were replaced 2k miles ago, but this noise has been there long before. Intake and EGR were cleaned 15k miles ago. Compression is 415/440/440/420 on a warm engine.
Idle, Engine Bay Shot.
Driving, 4k shift in 1st and 2nd, 3k into 3rd. Listen for that drone noise.
Driving, 4k shift in 1st, lower in 2nd. Listen for that drone noise.
Reving in Neutral
Note: The white wire you see is my VAG-COM cable plugged in and draped across and out of the way.
Reving in Neutral
