oldenburgd
Over 5 years later, this post is still helping! I'm glad I found this post, the video was very clear and helpful.
Ditto--will give it a go this coming week! Great job, Mike!Over 5 years later, this post is still helping! I'm glad I found this post, the video was very clear and helpful.
Unfortunately, I have no experience with removing the center console button. My brother had a Passat with a center console button that I was intending on repairing and documenting when the time came. Sadly, the vehicle was totaled before that.My 2015 Jetta TDI Comfort Line has the push start bottom on the center console.
Once in awhile it reads on the center dash NO IGNITION and have to hit start bottom again.
I assume the same problem.
Guess I will have to do your fix.
Removing from my center console looks to be a might bit harder for removal compared to steering column.
Thankyou for your fix
Just more involved in removing the button. More trim pieces must be removed. I’m sure it isn’t a terrible job, it’s just not as easy as the steering column mounted button.So the console buttons are more problematic than the steering column ones?
You rock man!!! Worked for me!
Cheers to you!Great write up… my tdi now starts with a light push rather than me smashing and banging my Head on the steering wheel. Cheers and keep up the great posts.
Amazon.com said:Currently not available
It is unknown whether and when this item will be in stock again.
