Troy909
I just bought a brand new 2006 Golf TDI. I had to fly to Wisconson to get it from AZ. One of the last ones as I am told.
So I drove 2100 miles home without issue. This morning, however, I took off for my work commute and 3 minutes into my drive I had issues. It was raining and the dash showed several codes:
1. #8 ASR/ESP
2. #21 MIL Malfunction Indicator Lamp (emissions)
3. #1 Airbag System
4. #11 Brake
ABS and airbag would flash and I got 3 beeps every 3 seconds for the whole 30 minute drive. The car is driving as though it is in its highest gear. I would get little spurts of power as I tried to speed up. Starting from a stop sign was very slow. Just enough throttle to get her moving but not realy get out of anyones way. I have an appointment in the morning at VW but I was hoping to speed things up there with some suggestions from you guys that have been around for a while. I also have a TDI Passat but have yet to have a problem with it.
Thanks for sharing.
Troy
1. #8 ASR/ESP
3. #1 Airbag System
4. #11 Brake
Thanks for sharing.
Troy
