Old August 14th, 2019, 18:46   #1
turbodan62
Default pvc oil catch can
a few years ago people were selling a pvc oil catch can for the TDI' s most for the alh & early engines . Is there a real need for them , and would you need them on a late 2.0 / 4 valve engine ??Thanks for all the info i can get Tdan
turbodan62 is offline   Reply With Quote
Old August 15th, 2019, 04:13   #2
oilhammer's Avatar
Fuel Economy: fantastic
Solution in search of a problem if you ask me.
www.cardocautomotive.com
Old August 17th, 2019, 05:49   #3
redbarron55
Probably for the racers where a catch can is required to keep some oil off the track.
redbarron55 is offline   Reply With Quote
Old August 18th, 2019, 06:01   #4
Mongler98
ive ran many types of DIY and kit catch cans on my TDI and i always end up going back to the turbo scavenge strait from the valve cover. there are only a few options that dont totally suck and its fairly pointless.
the only thing it really does is look fancy. even for my high 6500RPM reving AHU it was pointless.
spend your money in better places.
Old August 19th, 2019, 17:20   #5
dirtride
TDI(s): 2003 Golf
Fuel Economy: mid to upper 40's
Going against the grain, I have a pro-vent 200 with the drain back to the oil pan. Simple closed system set up. No problems with over 65k miles, just clean/change the filter.
Mark
03 GOLF ~ GLS ALH EGR (blended vehicle)
00 F-350 ~ 7.3 PSD 4WD ZF-6 XLT LBCC
dirtride is offline   Reply With Quote
Old August 28th, 2019, 15:24   #6
romad
romad's Avatar
My understanding is they help keep oil from the EGR out of the intercooler or are you discussing a different catch can.
Mark, can you provide a diagram of how you use the Pro-Vent 200?
The fleet:
romad is offline   Reply With Quote
Old September 10th, 2019, 13:24   #7
dirtride
TDI(s): 2003 Golf
I can take pictures from the top & post here.
But recently I had foot surgery so it may be a little while.
Mark
Old September 10th, 2019, 16:18   #8
hey_allen
I did the "agricultural strainer" using a strainer from Tractor Supply and some 3/4" hose from the breather and air inlet to the intake. A few stainless steel wool pads stuffed in the strainer give it somewhere for the oil to coalesce.
I do see some oil condensing in the breather-strainer tube, and no more than one little spot made it out, but it doesn't see much coming from the engine in the first place.
hey_allen is offline   Reply With Quote
Old Yesterday, 05:54   #9
Votblindub
Votblindub's Avatar
PVC is likely a cheaper alternative to the metal catch cans. It's mostly for people wanting to keep that oil residue out of their intakes.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Oil in the turbo air intake, oil catch can? sptsailing VW MKV-A5 Golf/Jettas 4 May 3rd, 2019 04:30
Princess oil extractor - tubing pvc too short jimmyto Ontario 4 October 7th, 2015 08:13
Oil catch can. WilburBeast VW MKIV-A4 TDIs (VE and PD) 1 June 30th, 2015 06:53
Oil catch can 4x4toy VW MKIII-A3/B4 TDIs 4 April 14th, 2011 13:06
PVC Oil Separator AU_Bug VW MKIV-A4 TDIs (VE and PD) 1 August 19th, 2004 13:57
Page generated in 0.14405 seconds with 12 queries
[Output: 90.73 Kb. compressed to 77.67 Kb. by saving 13.07 Kb. (14.40%)]
