Old October 29th, 2014, 12:57   #1
JohnWilder
Fuel Economy: Average 53.25 mpg (4.4 l/100 km) over the last six months.
Default Power Steering System
I just want to vent about VW. I've a 2003 Jetta TDI. I've heard a noise in the engine that seemed to coordinate with steering. It was noticeable at idle and then disappeared at speed. I assumed it was a quirk with the power steering system. Well, it got louder. That prompted a serious investigation. I discovered the PS fluid level was low, below the min mark. I topped it up and it is dead quiet. Everything is fine. I see no indication of any leaks anywhere.
Now my gripe. The owner's manual does not address the PS system at all other than to say not to hold the steering wheel over on the stops. It does not show where the reservoir is located. It does not spec the fluid. Nothing!!! This is a system that needs to be checked now and then and VW will not says a word about it. Inexcusable!
My vent. Thank you.
JohnWilder is offline   Reply With Quote
Old October 29th, 2014, 17:22   #2
nord
Well... You've vented. VW has disclaimed. The owner's manual is all but useless. And you still drive a VW. Either we're not too smart as a group or VW makes a good enough car for us to ignore those small irritations.
nord is offline   Reply With Quote
Old October 29th, 2014, 17:26   #3
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
The owners manuals leave a lot to be desired.
Old October 30th, 2014, 09:50   #4
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Should we tell him that the newer cars don't even have a fuse listing
-J
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
compu_85 is online now   Reply With Quote
Old December 24th, 2015, 03:08   #5
glassman
Fuel Economy: 47 summer, 43 winter
Sorry to resurrect an old thread, but what you should tell him is where the power steering reservoir is. (I don't know either--where is it, please?)
glassman is offline   Reply With Quote
Old December 24th, 2015, 06:52   #6
Ol'Rattler
Ol'Rattler's Avatar
I don't see the problem. I'm pretty sure the PS system's type of fluid is shown in the owners manual as well as how to check it.
I find it hard to believe that the owners manual does not tell you how to check the PS reservoir. You need to read the manual some more. Of course, VW owners manuals can be kinda lame, so anything is possible.
I find it unbelievable that someone would not check the level in their PS reservoir at least at every oil change. The Min and Max levels are very clearly marked on the side of the reservoir. Not VW's fault if you don't have a clue when taking on the responsibility of doing your own maintenance.
Something that kills me about folks recommending people can do their own maintenance because it's just so easy. Well with some folks, they have no business under the hood.
For those that don't know, PS level is checked with the engine idling and should indicate a level between MIN and MAX. If the level is low, you top off to the MAX mark with the correctly specified fluid.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 24th, 2015, 19:01   #7
where2
where2's Avatar
For those who didn't receive an owner's manual, the correctly specified fluid is generally Pentosin CHF 11S or Pentosin CHF 202.
http://www.idparts.com/power-steerin...02-p-1160.html
Contrary to some threads that say that you can only find this special fluid at your MB/VW/Audi dealer, roughly 25% of my local Advance Auto Parts store locations stock CHF 11S (behind the counter, must ask for it). It must be made from the juice of ground up $10 bills, because it's green and expensive...
'19 e-Golf SE (w/ DAP)
'13 Jetta SportWagen TDI, 6MT (4 Wife) 55k and counting...
'06 Jetta_TDI Pkg_1 5spd (wife's DD for 169k, RIP totaled)
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 232k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old December 24th, 2015, 20:29   #8
PGM jetta
TDI(s): 05 Jetta BEW
Does it not matter whether or not the engine/fluid is hot or cold? I was thinking it did
Sent from my XT1254 using Tapatalk
PGM jetta is offline   Reply With Quote
Old December 24th, 2015, 20:57   #9
JohnWilder
I've topped up the PS to full after about a year. I've no idea where the fluid goes. I cannot find a damp place anywhere yet it disappears over time. Beats me.
Old December 24th, 2015, 20:58   #10
Ol'Rattler
Ol'Rattler's Avatar
Good point. some dipsticks do have a hot or cold indication on the level indication. If your car does not have a hot or cold range, I would assume that the MAX mark would apply when the engine is at operating temperature.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old December 24th, 2015, 21:06   #11
PGM jetta
Sounds like the leak is on the low pressure side somewhere. If it was the high pressure, it would squirt everywhere and be easily noticeable
I haven't had to deal with any PS issues (knock on wood) so I don't really have any good suggestions on where to start looking. I would clean every hose and every connection. Then see where it gets damp.
The PS system is a closed system so it shouldn't ever need fluid added, much like the brake system. Notice I said shouldn't....
Old December 24th, 2015, 21:08   #12
PGM jetta
That's what I was thinking too. I can't remember off of the top of my head if mine(05 BEW) says hot or cold on it
Old December 24th, 2015, 21:17   #13
AndyBees
AndyBees's Avatar
Take a look in the link below .........
https://www.google.com/search?q=2000...&bih=589#imgrc=_
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old December 24th, 2015, 21:20   #14
Ol'Rattler
Ol'Rattler's Avatar
IIRC if my MK3 or MK4 had a hot or cold range. My recollection is they didn't. So ya, if the level never goes above MAX when the engine is warm and never goes below MIN when the engine is cold, you are good. Same way with the coolant in the coolant reservoir.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old December 25th, 2015, 20:44   #15
RacerTodd
RacerTodd's Avatar
Fuel Economy: about 50
The instructions in the Bentley manual for the MK4 state:
Cold: wheels straight ahead, engine off, fluid should be +/- 2mm of the MIN mark
Hot: wheels straight ahead, fluid should be between MIN and MAX
Todd
Seattle,WA
'86 GTI, Red of course. (exciting racey car) 274,000 miles
'01 Golf TDI, silver. (new work car) 558,000 miles!
'87 Golf, Polar Silver. (retired work car) 654,000 miles <- Gone to a new home
RacerTodd is offline   Reply With Quote
flushing power steering system greenskeeper TDI 101 1 October 10th, 2012 16:09
FS Power Steering System parts ALH 2000 Golf TDI forgottenzone Private TDI Items for Sale/Wanted 4 December 15th, 2010 21:02
Big Problem with Power Steering System maktas VW B5 Passat TDIs 8 October 26th, 2006 19:04
Does the TDI have a different power steering system? cocteau104 VW MKIV-A4 TDIs (VE and PD) 5 December 9th, 2005 19:44
Power steering system purge? or just the resevoir? madrean VW MKIV-A4 TDIs (VE and PD) 3 November 19th, 2004 15:01
Page generated in 0.18893 seconds with 11 queries
[Output: 132.50 Kb. compressed to 111.26 Kb. by saving 21.24 Kb. (16.03%)]
