Old May 19th, 2013, 16:16   #1
ADVNTURR
Default Need help to get selector gear off for 5th gear swap
I am in the process of converting my 03 Golf from an auto to a 5spd (donor was an 01 Beetle) and while I was at it I wanted to go ahead and upgrade 5th gear since it was already drained and was easy to access. I have the bolts off and the selector ring out of the way but I can not get the selector gear loose. I realize that it is pressed on, but I have been heating it and putting a lot of pressure (more that I am really comfortable with) on it with a 2 jaw puller but I have yet to get it to budge. I have also tried tapping on the gear with a wrench while it was hot and with the puller loaded, but still no such luck.
Has anyone who has done a 5th gear swap before had this much trouble getting the selector gear off? Any thoughts (I am concerned about shattering the gear with too much force and I don't want to put too much heat into it with a torch)?
Thanks in advance.
ADVNTURR is offline   Reply With Quote
Old May 19th, 2013, 17:53   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
I use a three jaw puller, with the ends of the jaws ground down so that they slide fully under the gear and selector ring. That and a little heat from a propane torch and the gear will pop off without too much difficulty.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
5th gear selector fork? MojaveGolf TDI 101 3 February 18th, 2013 18:23
Need TDI Gear Set from 5th Gear Swap smat2hews TDI 101 6 December 7th, 2012 06:32
How does the selection gear go back together? (5th gear swap) Nuje Upgrades (non TDI Engine related) 3 March 17th, 2008 00:18
Modified Gear Puller for 5th Gear Swap haraguchi TDI 101 0 October 30th, 2007 21:33
Modified 4" Gear Puller for 5th Gear Swap. haraguchi Private TDI Items for Sale/Wanted 0 October 30th, 2007 17:24
Page generated in 0.13141 seconds with 11 queries
[Output: 53.08 Kb. compressed to 49.05 Kb. by saving 4.03 Kb. (7.59%)]
