Old October 10th, 2012, 15:53   #1
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
Default flushing power steering system
Sourced a new vw rack for my 98, going to be installing this weekend.
I am wondering the best way to go about getting all the old oil out of the system so I can start fresh with vw pentosin fluid.
I've been milking the leaking rack along throwing everything at it to slow the leak, now I want to get everything cleaned out as best as possible.
How much pentosin do I need for a full fill?
Planning to measure tie-rods on old vs new to get it "close enough" to drive to the alignment shop.
Suggestions?
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old October 10th, 2012, 16:09   #2
loganbmx4gt
loganbmx4gt's Avatar
Grab two liters of Pentosin
Jack front end off car of the ground
Disconnect the return line going to the PS resivour
Put hose of disconnected line into a bucket so you or a helper can see the fluid thats being pumped into it.
With the car off but key turn to ACC, turn the wheel from full clock to full clock.
While watching the resivour pour good fluid in while this is being done to make sure it never runs dry.
When you see good green fluid coming out of the return line hook it back up and you should then be good to go.
I had to do this on mine because the fluid looked like mud!
When I put new tie rods on that is exactly what I did.
loganbmx4gt is offline   Reply With Quote
flushing the cooling system? ajrn VW MKIII-A3/B4 TDIs 1 November 27th, 2011 19:26
flushing cooling system jholetdi TDI 101 0 January 22nd, 2008 11:28
Flushing Brake system WillR VW MKV-A5 Golf/Jettas 9 April 24th, 2007 21:22
Big Problem with Power Steering System maktas VW B5 Passat TDIs 8 October 26th, 2006 19:04
Does the TDI have a different power steering system? cocteau104 VW MKIV-A4 TDIs (VE and PD) 5 December 9th, 2005 19:44
Page generated in 0.13326 seconds with 11 queries
[Output: 54.45 Kb. compressed to 49.91 Kb. by saving 4.54 Kb. (8.34%)]
