Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old August 15th, 2012, 23:17   #1
6thgear
TDI(s): 2011 Jetta
Default No more phone or Bluetooth
All of a sudden my radio stopped conNecting to my phone or my wife's phone. If I hit the phone button all it does is mute the radio. Anyone else experience this?
6thgear is offline   Reply With Quote
Old August 16th, 2012, 21:11   #2
bluelineman
bluelineman's Avatar
Mine did that a while ago. I had to re-synch them, not it works fine.
bluelineman is offline   Reply With Quote
Old August 17th, 2012, 00:00   #3
6thgear
TDI(s): 2011 Jetta
Resync how? I don't have a phone menu
Old August 17th, 2012, 06:43   #4
RebelTDI
You may want to shut the phones off, turn on and then reactivate the bluetooth connection on the phone.
RebelTDI is offline   Reply With Quote
Old August 17th, 2012, 08:05   #5
6thgear
TDI(s): 2011 Jetta
Tried shutting down the phone. It is like the Bluetooth is dead in the car. The phone does not see it
Old August 17th, 2012, 10:56   #6
Dimon80
Fuel Economy: combined 40 mpg
Here're the steps I would take:
- Delete the device (car) on your phone from bluetooth menu
- Turn bluetooth off
- Restart the phone
- Turn bluetooth on and into 'discover' mode
- Pair the phone with the car (instructions in the manual)
If you don't have the manual for the phone, do a goodle search and most of them are available online. The above steps usually work, but if they won't then I'd see a dealer (if the car is still under the warranty)
2009 VW Jetta TDI Blue 6M traded for
2010 VW Jetta TDI Cup Ed. Black 6M traded for
2012 VW Jetta TDI Pr. w/NAV Blue 6A traded for
2013 VW Passat TDI SEL Black 6A
Dimon80 is offline   Reply With Quote
Old August 17th, 2012, 20:19   #7
bluelineman
See below. That's what I was talking about. Delete the VW from your phone & re-pair them.
- Restart the phone
Old August 17th, 2012, 23:44   #8
6thgear
TDI(s): 2011 Jetta
Just an update. I unplugged the Bluetooth module. Plugged back in and all seems to be working. Cool
Old August 30th, 2012, 05:04   #9
Drive The Deez
Where is the module located? Did you unplug and re-plug with power off or on?
Mine just stopped syncing last night and I spent an hour deleting profiles and trying to re-sync. At first I thought it was just a ROM I had flashed causing problems, but since the microphone button on the steering wheel stopped working as well I figured something was wrong. Doesn't sync with wife's phone anymore either.
EDIT: Found where it's located. Going to give it a try with power off first and see if that fixes the problem.
Drive The Deez is offline   Reply With Quote
Old August 30th, 2012, 06:30   #10
Jettagain
Fuel Economy: 44
The module is under the passenger seat. Mine has been doing this for a while as well. I have noticed that when it isn't working, the phone has a message stating the phone book is being accessed and it will actually keep flashing this on the phone eventually draining the phone battery. I tried re-pairing, deleting and re-installing....finally unplugged the BT module and it did start working correctly again. Never had to do this in any of my other vehicles...but i make that statement a lot with my Jetta....
Jettagain is offline   Reply With Quote
Old August 21st, 2014, 17:29   #11
Archmetal
Default Fix
Looks like the unplug and replug of the module under the passenger seat seems to be the fix for me. Tried this and it fixed the issue!! Thank you.
Archmetal is offline   Reply With Quote
How To: Bluetooth phone/radio interface MOGolf VW B5 Passat TDIs 28 November 22nd, 2013 18:44
Another I Phone 4 Bluetooth Issue pdh VW MKVI-A6 Jetta Sedan (~ 2011+) 1 October 14th, 2011 12:51
Bluetooth cuts out during phone call Highline Driver VW MKVI-A6 Jetta Sedan (~ 2011+) 3 June 12th, 2011 11:45
How do you switch from bluetooth to phone sinfony78 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 October 22nd, 2010 21:00
Bluetooth/cell phone connection Miata6 TDI 101 2 August 11th, 2010 09:16
Page generated in 0.18436 seconds with 11 queries
[Output: 101.39 Kb. compressed to 85.50 Kb. by saving 15.89 Kb. (15.68%)]
