Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old October 14th, 2011, 12:26   #1
pdh
Fuel Economy: 42/49 VW, 38/42 BMW
Default Another I Phone 4 Bluetooth Issue
I have a 2011 Jetta TDI purchased in March. I got an I Phone 4 (4) weeks ago and the problem is that, in order to pick up my office voicemail I need to "prompt" *7, then my extension number and a password. If I call through my phone (via contacts) there is no problem. If I try to call through the Jetta Bluetooth with "Call Office at work" command, I get my automated switchboard but the prompt is not recognized and I then need to put the prompts in manually. If I call through the phone and later use the "re-dial" voice command on a subsequent call, the call goes through to my voicemail fine. If I turn my car off, the call won't go through again. I've tried to add all kinds of "waits" but the prompts just aren't recognized......only through the contact list will it work. I've talked to my dealer, Apple store and Verizon but no one can help me. I did not have this problem with my BlackBerry. Any help would be appreciated.
pdh is offline   Reply With Quote
Old October 14th, 2011, 12:51   #2
NickBeek
I have some entries with "pauses" in them to dial a customer's extension that work fine. Others that do not. I never got a "wait" to work at all. If you change the entries to "pauses" it should work. The only problem is the phone book from our phone gets stored in the car's BT system. I don't think it updates when you change contact info on the phone. I've been meaning to re-read the owners manual for the BT system so I can figure out how to purge the BT phone book and re-load it from my phone, but haven't had the time.
2013 Passat TDI SE with Sunroof DSG Platinum Grey.
Traded - 2011 Jetta TDI Sedan Manual 6 Speed Silver.
NickBeek is offline   Reply With Quote
How To: Bluetooth phone/radio interface MOGolf VW B5 Passat TDIs 28 November 22nd, 2013 18:44
Bluetooth Hands-Free Phone Interface Neilheeney Audi A3 7 June 14th, 2011 02:01
Bluetooth cuts out during phone call Highline Driver VW MKVI-A6 Jetta Sedan (~ 2011+) 3 June 12th, 2011 11:45
How do you switch from bluetooth to phone sinfony78 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 October 22nd, 2010 21:00
Bluetooth/cell phone connection Miata6 TDI 101 2 August 11th, 2010 09:16
Page generated in 0.11945 seconds with 11 queries
[Output: 52.91 Kb. compressed to 48.94 Kb. by saving 3.97 Kb. (7.50%)]
