Old October 22nd, 2010, 00:50   #1
sinfony78
Default How do you switch from bluetooth to phone
How do you switch to the handset while the bluetooth is connected in the middle of a phone call? is there a button to push?
i have an early model 2010, if that makes a difference. No navigation system
2010 jsw tdi
sinfony78 is offline   Reply With Quote
Old October 22nd, 2010, 06:41   #2
numl0ck
numl0ck's Avatar
Fuel Economy: 40
It depends on the type of phone you have. On the iPhone, there is a "sources"-type button (I don't recall the exact name), and you can select speaker (normal), speaker phone, or bluetooth.
2010 Golf TDI, Black 4 Door, 6M, DG Sigma 6, Golf Ball Shift Knob, Panzer skid plate, Custom Garage Door Opener. I have a VAG-COM and am willing to share.
numl0ck is offline   Reply With Quote
Old October 22nd, 2010, 08:32   #3
sinfony78
Is there a button in the car that will do it? Does it have to be done on the phone?
2010 jsw tdi
Old October 22nd, 2010, 08:35   #4
numl0ck
numl0ck's Avatar
Fuel Economy: 40
I'm pretty sure it has to be done on the phone.
For what it's worth, you can turn the car off, and when you remove the key from the ignition it will auto-swich back to the phone (not much use when you are cruising down the highway).
Old October 22nd, 2010, 12:04   #5
Chilkoot
Chilkoot's Avatar
Hit the phone button on the left side of the steering wheel twice (quickly) and the call will switch to your handset. Hit it twice again and it will go back to Bluetooth.
_____________________________________________
2010 JSW Black/Titan, 6M, Pano, Portos, MDI, Protection Package, Stainless Exhaust Tips
1997 Ford Explorer XLT
1995 Saab 900 SE, 5sp (with the dreaded V6)
1990 Toyota Camry All-Trac, 5sp
1983 Ford Econoline Van with Universal Conversion
3sp(+OD) manual trans. and lots of windows
1975 Saab 99LE Sedan, 4sp.
Chilkoot is offline   Reply With Quote
Old October 22nd, 2010, 14:09   #6
sinfony78
thanks, i'll try that...i searched through the bluetooth manual and it said nothing about this..but i just skimmed through it really, really fast
2010 jsw tdi
Old October 22nd, 2010, 16:46   #7
numl0ck
numl0ck's Avatar
Fuel Economy: 40
Good to know!
Old October 22nd, 2010, 17:03   #8
tcp_ip_dude
tcp_ip_dude's Avatar
Fuel Economy: 46@75mph/51@60mph/City 38mpg
All the BT features are well covered in the manual. i.e. muting, transfering, handsfree, phonebook access, ring volume, etc.
'10 Jetta 6M Sedan, 35% Llumar tint, WeatherTech Floor Liners, TDIclub Plate Frame, B2, PS, ScanGauge II, Micro-Can VAG-Com
tcp_ip_dude is offline   Reply With Quote
Old October 22nd, 2010, 18:53   #9
Camarones
You could just turn off the car
(not recommended while in motion!)
2015 Mercedes-Benz GLK 250 Bluetec
2010 Outback 2.5i Premium CVT
2010 Golf TDI -- 6MT United Gray 4 Doors buyback Completed!
2001 Golf TDI SOLD! -- Thanks Harvieux!
Camarones is offline   Reply With Quote
Old October 22nd, 2010, 21:00   #10
sinfony78
i tested it, and i had to hold down the phone button on the steering wheel in order to transfer the call to the handset...always thought the only function of that button was to hang up
2010 jsw tdi
Page generated in 0.13010 seconds with 10 queries
[Output: 91.50 Kb. compressed to 76.78 Kb. by saving 14.72 Kb. (16.09%)]
