Old February 25th, 2010, 09:47   #1
johnjames1234
johnjames1234's Avatar
TDI(s): golfvan
Default ALH valve guides/valve stems??
hi guys. has the ALH got valve guides AND valve stem seals???
many thanks
john.
93 honda crx del sol V-tec
95 golfvan 1.9(SOLD)
04 golfvan 1.9TDI (SOLD) ;-(
02 CADDY 1.9TDI (SOLD)
89 toyota corolla van 1.8D
johnjames1234 is offline   Reply With Quote
Old February 25th, 2010, 09:53   #2
far_cry
far_cry's Avatar
i think all cars have them
2002 Skoda Octavia 1.9 TDI ALH AT
far_cry is offline   Reply With Quote
Old February 25th, 2010, 09:54   #3
johnjames1234
TDI(s): golfvan
so they have both??
Old February 25th, 2010, 09:56   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Not all engines have both, but these do.
oilhammer
www.cardocautomotive.com
Old February 25th, 2010, 12:32   #5
johnjames1234
TDI(s): golfvan
ah good, oilhammer a name that can be trusted
so when im ordering valve guides ill order stems too yeah oily??
oh" can both be replaced with head still on???
cheers mate
Old February 25th, 2010, 12:44   #6
oilhammer
oilhammer's Avatar
Are you serious? You may want to get a shop manual, maybe even a basic book from the library on engine repair. The VAG SOHC engine is pretty textbook. And yes, you need to remove the head and completely tear it apart to replace guides. With the right tools, the stem seals can be replaced on the car but rarely are they needed.
What problem are you trying to "fix"?
oilhammer
Old February 25th, 2010, 12:48   #7
johnjames1234
TDI(s): golfvan
i have haynes manual..
yes im serious.
Old February 25th, 2010, 13:48   #8
oilhammer
oilhammer's Avatar
yes im serious.
Forgive me for being blunt, but I would have assumed someone that even knew how to type "valve guide" and "valve stem seal" would know the basic anatomy of an automotive cylinder head. To me this is akin to a dentist asking "Are your teeth located in your mouth?"
I suggest some time in your local library, perhaps reading some engine or machine shop type books.
Again I ask, what problem are you trying to solve?
oilhammer
Old February 25th, 2010, 14:09   #9
johnjames1234
TDI(s): golfvan
oh yeah sorry never read ...
i have blue smoke on idling ,its using oil quarter L every 3k miles. compression test done thats fine. believe it or not i actually have a few automotive books
oily some V stems can be replaced without removing the head.not all engines ,BUT some thats why i asked about the ALH.
http://www.ehow.com/how_4477803_valv...ing-heads.html
cheers john
Old February 25th, 2010, 14:30   #10
oilhammer
oilhammer's Avatar
I would love to see any car engine you can replace valve guides on with the head installed, LOL.
You may have an OIL ring problem. Yes, you can have good compression and still have an oil ring problem. In actuality, your compression can be outstanding because the bad oil ring allows the compression rings to seal better.
oilhammer
Old February 25th, 2010, 14:37   #11
johnjames1234
TDI(s): golfvan
oh bloody hell dont say OIL ring.....
well i guess its head off then boss.
sure you never know... I MIGHT ACTUALLY learn something ;-)
cheers man.(bloody MR know it ALL !!! ;-) )
Old February 25th, 2010, 14:48   #12
Ski in NC
Fuel Economy: 48-52 typical
A quarter liter of oil in 3k miles is about normal. I this what you meant?
Blue smoke at idle with cold engine is often unburnt fuel. Blue smoke at idle with hot engine can be turbo seals leaking oil.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old February 25th, 2010, 14:50   #13
johnjames1234
TDI(s): golfvan
Old February 25th, 2010, 15:06   #14
johnjames1234
TDI(s): golfvan
yeah thats what i mean.
any way of knowng its the turbo seals.... without doing some serious striping?
only blue smoke when idling hot or cold.
smoke clears after very short drive. but if left too idle after drive smoke comes back
Page generated in 0.16301 seconds with 10 queries
[Output: 120.04 Kb. compressed to 99.28 Kb. by saving 20.76 Kb. (17.30%)]
