Old October 22nd, 2006, 14:43   #1
maktas
maktas's Avatar
Default Big Problem with Power Steering System
Ever since I purchased my Passat TDI last summer, I had a problem with loss of power steering fluid. I noticed this problem when I starting hearing a "groaning sound" typical of a power steering pump starved of fluid. Since then, I brought it back 5 times to 2 different stealerships and the problem just came back. Here is the timeline:
1. 8/5/16 - Suburban Imports Farmington Hills (VW Dealer),
" Client states power steering fluid is leaking, found p/steering low in vehicle (no kidding ), found pressure line was leaking at the crip (??) were the rubber and metal come together
Replaced pressure power steering line.
Parts:
Flex Hose- 8D1-422-893-AL
Washer - N-013-848-7
Washer- N-013-849-5
Oil G-002-000
2. 10/12/05 - Suburban Imports Farmington Hills (VW Dealer),
"Customer States there is fluid under the pront of vehicle where it is parked and the power steering makes a groaning noise."
"Cleaned power steering fluid from the power steering rack, sprayed leak trace on rack, checked for leaks, verified the seals at the power steering rack of the pressure line were leaking fluid."
"Replaced seals for pressure hose at the power steering rack"
Parts:
Washer- N-013-849-5
Oil G-002-000
(So they did the same thing as before...... , nothing new bastards@!)
3. 25/10/05- Volkswagen of Windsor (my dealer)
"Leaking Power Steering fluid" (really??)
"Removed and install pressure Hose (sounds familiar )
Parts:
Pressure Hose (??)
Oil G-002-012
4. 28/12/05- Volkswagen of Windsor (my dealer)
"Power Steering fluid keeps going low" ( )
"Remove and Install Clamps"
Parts:
Clip: X-100-004
5. 2/18/06- Volkswagen of Windsor (my dealer)
"Power steering fluid is low- has been checked before (not too much )- replace high pressure hose seal and clamps"
"Remove and install power steering gear" (I am assuming this is the entire rack?)
Parts:
3B1-422-052-RX Steering (rackassembly??)
Washer- N-013-849-5
So what should I do? Is this a wide spread issue? Why are VW techs incompetent? Is it a design issue or a quality issue? Where is VW engineering's DFMEA? I am pissed!!
2005 Passat TDI GLS, ST tune (gone after GP recall flash ), Reflex Silver, aftermarket HID 5000k (both headlight and fogs), chainless as of 4/18/09
maktas is offline   Reply With Quote
Old October 22nd, 2006, 15:04   #2
maktas
maktas's Avatar
Does anyone have the power steering system diagram they can sent to me? (from the CD??) I need to understand what the hell is going on.!
Old October 23rd, 2006, 15:31   #3
maktas
maktas's Avatar
Thanks for the help guys!
Old October 23rd, 2006, 15:54   #4
vw4life
vw4life's Avatar
Fuel Economy: 7.4 L/100km 75% city (~32 MPG US)
Sorry to hear about the problem I hope you can get it figured out. Sorry I have no resources to offer help.
\\\ David /// 2005 B5.5V TDI Stonehenge Grey - Manual Headlamp Leveling - Aspherical Mirrors - Ventectomy trouble? - Fuel Economy - Euro trailer hitch: towing, install, safety chains, towing, wiring, euro bike rack! +Factory de-tooef's, Airlift
vw4life is offline   Reply With Quote
Old October 23rd, 2006, 17:17   #5
vw4life
vw4life's Avatar
maybe you will get some more info here:
http://www.passatworld.com/forums/forumdisplay.php?f=37
Old October 23rd, 2006, 17:18   #6
TheGrove
Sorry, but I didn't have access to my Bentley's until now. Hope these help.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old October 23rd, 2006, 17:19   #7
TheGrove
Old October 24th, 2006, 09:36   #8
maktas
maktas's Avatar
Thanks!
I
Old October 26th, 2006, 19:04   #9
maktas
maktas's Avatar
The dealer says there is a stress crack at the rack where the high pressure hose terminates..... They are ordering another new rack..... either this is a lottery like chance, or they are not root causing this issue.... they changed everything except the pump, which is probably the key to this whole thing.... but they don't listen to me.
Page generated in 0.15971 seconds with 10 queries
[Output: 93.91 Kb. compressed to 80.00 Kb. by saving 13.91 Kb. (14.81%)]
