2ManyKMfor1Tank
Hey all, figured I'd start a new thread for the garage floor job.
It has been a long process - not the ideal thing to start when you have very limited time to spend doing it, but I think it'll be worth it in the end. I made mistakes along the way, and probably wouldn't be doing it at all if the concrete slab had been poured correctly and taken care of.
First of all, I started this project last fall, as the entrance to the garage had about a 1' x 6' or so area of damage, in some places the concrete failed and the area was badly checked not allowing for a good seal of the garage door. We were already noticing that on cold days the heat in our master bedroom was insufficient, which is directly above our garage. I figured the seal on the garage floor/door was important so decided to tackle it. I wish I had taken pictures of the floor before I started chiseling, but didn't think of it at the time. Here is what it looked like after I chiseled out the entrance:
Its hard to tell from this perspective, but I was aiming to make a small trough and at the time was planning to just repour regular cement to fix it. After talking to quite a few people, decided to use a cement patch which has an epoxy agent and is supposed to be much harder and bond well to the existing cement.
Looking back this still wasn't the right move though, I didn't know about epoxy at the time and there would have been no need to do all the chiseling that I did which took about 75% of the time of this entire project.
Here are some more pics of the floor, including some post-patch work.
Post Patch:
Only use this tool for chiseling concrete if you really hate yourself:
The proper tool was about $750 and much larger than this one - figured it was overkill.
Post Patch:
This is after I used the floor grinder:
This is what the difference looks like from before and after grinding:
You can see on the left the swirly scratch marks from the grinder - this is the result of one
pass from the grinder. It was terribly slow, I spent more than 12 hours essentially
wrestling a 400 lb machine across the floor countless times.
Time to quit for the night, end result so far:
I'll keep updating this as I go, am about 3/4 done the grinding - probably going to let it dry for a couple of days
and then do some finer patching as I have some small divots here and there.
I'll post more pics of the actual epoxy later this weekend or early next week.
Post Patch:
Post Patch:
