freeantelope024
I have a 1999.5 so far have replaced the head in cylinder 1, cam shaft, new timing, tensioners water pump...whooo hoo. The valve on the turbo was replaced (rusted shut) and re calibrated. Now occasionally as I accelerate there will sometimes be a sputter around 3000 rpms (manual) at whatever speed, and I will no longer have the use of the turbo until I cycle the key and it temporarily fixes the issue. Is this an intake problem in the turbo valve again, or possibly an MAF issue?
Thanks in advance
Jason
Thanks in advance
Jason
