ABS light in my 99 jetta 1.9 has been intermittently coming on and off. Finally had it scanned with VAG-com and the tech told me right front wheel speed sensor is throwing the code. Problem is I just got down replacing the hub assembly and wheel speed sensor with parts from fixmyvw.com
Told the tech that and he said it was most likely a cheap wheel speed sensor I put in and nothing compares to the OE kind.
Is this true, about ready to order a new ATE wheel speed sensor from IDparts for $70 but wanted to put the feelers out for ideas before I place the order. Do the connectors go bad?
Note - I did put dielectric grease on the connector at the hub and ABS unit. I have not really inspected the wiring yet but will do so.
