Old October 15th, 2019, 19:48   #1
JettaCR140
Default Any high power 02q trans TDIs
I have a 2009 cbea tdi with the 02q trans (steel synchros) with a gtb2260vk and bunch of other goodies. My DKM twin disc + SMF is starting to slip. Wondering if I should switch over to the darkside DMF kit or see if its possible to swap in a newer (I think 2015+) 02q as Ive heard they have brass synchros. Let me know if anyone knows as the car will likely be getting a cp3 and head studs in the next year. Thanks!
JettaCR140 is offline   Reply With Quote
Old October 16th, 2019, 08:40   #2
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
The early 02Q in your car might actually have brass synchros unless you've been in there to see for yourself. If they're steel and they've lasted with an SMF setup, consider yourself very lucky. The later 02Q boxes have steel and will not hold up with a SMF for very long.
Do you have any gear clatter in low speeds, or synchro rattle at idle?
That's disappointing to hear the DKM twin disc is slipping, I thought they were rated pretty high for torque.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is offline   Reply With Quote
Old October 16th, 2019, 17:06   #3
JettaCR140
Im almost certain they're steel as it was VIN checked by DarksideDevelopments and I did tons of research myself last year. I love the clutch and am also surprised it's slipping but the car does make tons of torque.
It has crazy chatter at idle (I hold the clutch in at a stop to avoid it) and also some at idle in gear, regret not just going DMF the first time but thankfully haven't broke any synchros.
Old October 16th, 2019, 18:25   #4
Yourbuddysatin
Fuel Economy: 32-35mpg
Sure it’s not your throw out bearing making noise?
Yourbuddysatin is online now   Reply With Quote
Old October 16th, 2019, 20:23   #5
JettaCR140
It could be the TOB but I think its more likely flywheel chatter. Main issue is the fact that its slipping though, I can live with chatter if it'd hold power its just annoying
Old October 16th, 2019, 23:21   #6
turbobrick240
turbobrick240's Avatar
It's gear rattle from the harmonics of the 4 banger tdi. The DMF is there to absorb most of the harmonics. A straight six doesn't produce nearly as much. My five cylinder golf makes quite a bit of gear rattle in neutral too. I'd look into the Sachs SRE dmf kit from darkside.
Old October 17th, 2019, 06:15   #7
adjat84th
adjat84th's Avatar
A DMF will certainly get rid of the noise, and a fluidampr would get rid of most of it if you stayed with a SMF. The Sachs SRE with organic disc I have is very pleasant to drive. Though, at your power level the sintered disc might be the way to go just for some added headroom. SouthBend has a setup for DMF use as well.
Old October 17th, 2019, 10:06   #8
TheoSweden
TheoSweden's Avatar
So you mean that if I put a 10kg SMF with my 02Q from 2012 it wont hold?
My 02M with 7KG SMF still goes strong after 12 years. Does 02M have brass syncros or why does it last?
2001-Audi A3 TDI Q 300hp racer since 2007 still going strong.
2006-Golf TDI Cup car soon 4WD 300hp+ etc. Going to be a fast circuit racer.
2008-Audi A4 TDI Q 300hp daily, not used, engine going into the Golf.
2015-Passat TDI 4M 240hp now 295hp/613nm fantastic daily driver.
TheoSweden is offline   Reply With Quote
Old October 17th, 2019, 17:29   #9
JettaCR140
Yes the 02m has the brass synchros and works great with a SMF, the 02q typically does not, although I was told the newer 02q (like 2017+ don't quote me on that) switched back to brass. Fluidamper will get rid of noise but has very limited info stating that it saves the synchros, I spoke to multiple people running SMF + fluidamper and still destroyed them.
I spoke with darkside today and it sounds like the Sachs SRE + sintered disc (for the cr170) will fit my car (its a US cr140) and is rated at 599 ft/lbs which is a little more than the DKM one I have now is rated at.
Southbound does makes a DMF kit but its over $2000 so I'm not interested in that.
Old October 18th, 2019, 09:47   #10
adjat84th
adjat84th's Avatar
You may be able to find the Southbend kit cheaper than that. I don't know why that thing costs what it does, but when I called them they confirmed it's just a Sachs DMF...nothing magical there. I believe IdParts might have the PP and Disc for a DMF setup.
Interesting if VW switched back to brass in the latest 6spds. May need to do some investigating on that one. You CAN swap an 02M 1-4 output shaft into the 02Q, but that's likely to cost a good bit when you could just find a full 02M for similar price.
Old October 18th, 2019, 14:14   #11
KERMA
KERMA's Avatar
What is the car doing during this "slip"
1) RPM increasing a lot without moving the car faster... up 500-1000 rpm then back down
2) shakes the car but RPM still matches road speed
I'm asking because lately a lot of guys are saying "slipping clutch" when they really have shudder. They aren't the same thing.
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old October 18th, 2019, 20:41   #12
JettaCR140
Good point, but its definitely slipping. It's inconsistent but if I get on it every once in a while RPMs will shoot up with inappropriate (no) speedometer acceleration and then will grab a moment later after I let off throttle, its quite obvious if you've been cars with slipping clutches before.
Old October 30th, 2019, 05:49   #13
Darren_0203
TDI(s): 2012 mk6
Very interested to see if we can swap to the newer transmission and if it has brass syncros. I tried finding out what the scope of clutch/tran options were available for our cars on here with no useful response, glad you're having better luck.
Darren_0203 is offline   Reply With Quote
Old October 30th, 2019, 06:40   #14
adjat84th
adjat84th's Avatar
C'mon now, you have two different threads here and here with plenty of useful info. I just think you wanted an answer that doesn't exist unfortunately. If you want to run an SMF, you need to swap to an 02M gearbox or put the 1st through 4th gear output shaft from one into an 02Q. There is no high performance DMF out there, and honestly once you start making near 400lb-ft of torque you don't want it below 2500rpm because something else is likely to break at that point. DMF shudder only shows itself below that, so a bigger turbo is going to likely solve that for you anyway.
Old October 30th, 2019, 10:36   #15
TheoSweden
TheoSweden's Avatar
This is funny
Are you guys sure that there is a real issue with this syncros and SMF??
I have shipped my 02Q gearbox to Darkside England and they tell me they never had any issues with this combination. Im spending quite much money here and its not fun if it goes to pieces after a short time.
Theo
FULL 02Q/02M OEM Trans Rebuild Kit 6-Speed HYDE16 Private TDI Items for Sale/Wanted 0 January 30th, 2018 10:23
Tdi 02q trans question nsrt4 TDI Conversions 2 February 2nd, 2016 21:22
torque/power limit in 02Q v8 coupe TDI Power Enhancements 0 October 7th, 2014 17:31
Correct trans oil for 02Q? ibexlatham VW MKV-A5 Golf/Jettas 3 March 6th, 2013 20:51
Manual Trans 02Q Questions whiplash willy TDI 101 10 June 19th, 2012 11:26
Page generated in 0.20692 seconds with 13 queries
[Output: 133.56 Kb. compressed to 112.12 Kb. by saving 21.43 Kb. (16.05%)]
